We value your privacy.
These are some of the pictures of the wood planes that are part of theset of tools. I also have several chisels and assorted measuring tools. I have also included documents that were in the tool box to document when and where he worked. The tool box was I am thinking was made by him. I am trying to learn a little history about the tools. The wood planes have a name stamped on them, A. Nilson, not sure if he was the original owner of the tools, or he made them. And did they make their own planes?
Attached is a link to a photo album containing pictures.
Let me preface everything by saying that I worked in the San Francisco bay area and there are different traditions in other areas of the country
Most of the tools pictured look like typical molding planes which are not used by patternmakers. There are a couple of exceptions such as the triangular box plane which is a shop made corebox plane and there is a small wood block plane next to a wood bodied spoke shave. If that has a radius bottom it is a patternmaker’s corebox plane.
A core box plane like the triangular box was used to make a perfect half circle channel in a block of wood. You would start by drawing the desired profile on each end and then hogging out as much as possible on a table saw. The key is to cut the sides accurately with the blade of the saw at an angle. Then set the blade to take a light cut and work it from one end to the other and slightly rotate it on each pass. Then set the blade deeper and keep repeating till you hit your marks. This kind of core box planes were made obsolete with accurate spindle sanders like those manufactured by State, Oliver, and Max ad would have been mostly obsolete by the time your guy was working.
The wood plane with a curved sole should have the radius stamped on one end. It was for shaping a portion of a corebox to that radius. Some of the uses of this type of corebox plane were superseded by the spindle sander but there were still used a bit and finally made obsolete by the invention of low shrinkage two part urethane castables sometime in the 60’s
It is common for patternmakers to make some of their own tools box as well as a tool box and it was also common in some areas for the Union to give them a Gerstner box when they finished out their apprenticeship. Another tradition was that once it was known that an apprentice was not likely to wash out they were given the chance to buy a set of tools from the widow of a deceased patternmaker. The going rate is one weeks pay. (This is dying out a bit as tools are becoming collectable) This is usually not even close to the cost of buying the tools and it is often not a complete set as some of the heirs will often take things like squares or some of the common hand tools. The set of tools I bought came from a patternmaker that had apprenticed during WWII at Mare Island near Oakland CA and also included a few older tools. on them and some with L.O. on them
The most common type of tool box for patternmakers is a Gerstner style drop front box, but I have seen some that were just a simple set of drawers without the hinged top or the drop front. It is also common to have a wood chest with a simple hinged top and possibly a simple till for all the spillover and large stuff. This box is not a box that is worked out of and is rarely ever gotten into. I have seen some of the younger patternmakers use Kennedy metal tool boxes and even one guy that used a metal craftsman box. The box rarely speaks of a patternmaker’s skill; it is more about his love of tools.
At the bottom of each pic on photobucket is a series of boxes, if you copy the box that says IMG code and paste that into your message here the picture will be in your post. You can test it out by hitting ht preview button before you post the message and I highly recommend this to make sure you didn’t double post the same pic. DAMHIKT
Let me know if you post more pics and I’ll take a look and offer what I can.
I'm using internet explorer and I just copied the url and pasted it into the browser. I havn't used chrome very much but from what little I did I thought it worked just fine. Maybe your computer was just having a bout of indigestion.
Some interesting pattern makers tools you might look for are "shrink rules". Since the metal castings shrink as they cool, the rules are made deliberately oversize so that a pattern measured with the shrink rule will give an accurate casting after shrinking. There are different rules for different metals.
I did some research on pattern maker Steve Kovacik, 4223 Walton St, Chicago, as shown in your documents. He was born Steve Kantor in Slovakia, Oct 1906. Kovacik was his stepfather. He died in June 1944 in Chicago.
One of the ways you can identify a patternmakers tool box is that the drawers are always well over 24" wide on the inside to accomodate the various two foot shrink rules which can measure up to 24 3/4" long.
A common rule accesory for patternmakers is a rule holder. These were made comercially, but I have also seen a lot of shop made ones. if you use a height guage it is denominated in standard rule, and if you use it on a pattern you then have to do the math to convert to shring rule equivilants using a calculator or a printed shrink table. A less error prone way of working would be to use a surface guage and set it using a shrink rule. To make this easier and more acurate a rule holder is used to hold the shrink rule 90* to the work surface.
Finally saw the pic (thank you !). Really didn't see anything "pattern" there. I'd guess more "molding Dude" for house construction. I assume pre-#45 plane. When did THAT come out ?
