Re: Thank you for buying a California tool
TomD
I think it is a myth that Ti hammers hit above their weight. The Ti hammer craze hit at the same time that the Ti driver craze hit. If a Ti driver was worth 500 dollars (at the time a quantum increase in cost) then a Ti hammer had to be good also. Ti drivers, however were not lighter, not even by a gram than Steel or wood drivers, they were larger. Any performance increase there may have been was based on engineering more forgiveness, and a larger sweet spot. They are generally longer in the shaft which is a really upsetting factor in golf swing dynamics, and therefore, having a large head is hoped to make up for that increase in length, and come out better in the end.
On hammers, to breeze past the math, basically you have to increase swing velocity by a quantum that sounds small but is highly significant. It works out to be the same amount that distinguishes par golfers from PGA tour player averages (I did these number at the time this stuff came out), and PGA tour average from the long hitting champs on the tour. In other words it is not an amount you can just pour on, any more than I can just go out there and hit it as far as tour pro by jumping on it a little.
There may be differences, such as that you can jump on it a little because nails are not as hard to hit as golf balls (maybe); Lightening a hammer by a third does make some increased swing speed possible. Many hammerers, can't sink a framing nail in one swat anyway, so their idea of "the same" may be a matter of loosing count of the blows; Until not so long ago, in many parts of the country framing hammers were not the California style, and a 16 oz claw hammer was used, so a 15 ounce long handle hammer is more powerful. There is a difference between swingers and hitters. Basically swingers use the weight of the head. So if you swing, you are likely noticing that something is missing. If you hit, this hammer may suit you better, particularly if you believe it is the equal of a steel hammer.
Anyone who thinks a long shaft ti hammer of 15 ounces hits as hard as a 21 ounce steel hammer, needs to explain why a 15 ounce long shafted steel hammer would not work as well. Particularly when a lot of framers choke up on the shafts to regular length much of the time. There is no evidence I am aware of that Ti has some magic properties. Magic properties have been suggested for other materials, like beryllium (you guessed it, it is extra heavy), over the years, but normally they don't catch on.
Ti hammers are perfect for those who want to carry a hammer, but nail a lot with a gun. It is a lot lighter to carry, and it works pretty darn well. Ti hammers can spark when they hit grit, particularly noticeable at dusk. So if there is an explosive hazard in the area you work in, not a typical framing issue, but common in wreaking, it might be worth asking the manufacturer about any such risks.
I own two Ti hammers, a Stiletto and a Dalluge, and and would probably own more if there were more to try out. But the Ti versions of finish, roofing, and drywall, hammers do not sell around here.
