New WoodChat!
A55 Smoothing Plane
Encouragement for the newbies
Rononkokomo
I am not exactly a newbie, but I have been out of the shop for almost ten years . And when I was in the shop, I did not do much handsawing. I have been back in the shop for a couple of months. Probably 12 hours a wheel. I have had real trouble sawing plumb. All of a sudden, for the last two days, my cuts are square and plumb. Press on. You will develop the balance and muscle memory that you need. As I have said here before, your twentieth dovetail joint will happen a lot quicker and look better than your first one.
Re: Encouragement for the newbies
Michael Donaldson
Michael Donaldson
Well, when your skills are as rock-bottom as mine, it can only get better. Thanks for the encouragement. I still stink, but I'm having fun working on it.
TomD
As FK says, amended for my experience, "after 53 years of cutting bread and dovetails you will be a pretty good beginer too". Best advise I can give is to concentrate on getting the saw to cut smoothly at a regular pace, and just let it fall through the cut. Have a comfortable stance that provides full freedom of movement. When choosing saws, make sure they can cut smoothly, and the far higher end hope is that they really do just fall straight, that gets pricey as the kerf ration narrows.
Second bit of advice is to practice. Even if you have power tools, take on some jobs now and then that have some repetitive cuts and just enjoy the process.
3rd. Before an important job, if you don't do this stuff every hour, get some scrap and drop some cuts side by side, to get the flow going again, then hit it.
Tom that is wisdom
