New WoodChat!
Stanley Rule #13
Stanley Rule #13
Stanley Rule #13
Don Evans
Hi all;
I'm usually on the turning forum but have a friend who has part of a Stanley Rule and Level #13 plane. He has asked me to see if I can find parts for it but I'm not versed in planes other than using one occassionally.
Can someone point me to a place to read up on the different part names so I can see if I can locate missing one's?
This is one with wooden base, the metal part that holds the blade is there but I don't know if this one had a chipper(?) or how it locked the blade in that is missing also. Dimensions of blade etc would be good as a new one will have to do if cannot find original stuff.
He knows it has no real antique value and just wants it to work. Any help appreciated!
Don
Re: Stanley Rule #13
Re: Stanley Rule #13 *LINK*
The #13 was a circular (compass) plane. Are you sure that's what he's got?
You can find a discussion of all the Stanley planes (and some related tools) on "Blood and Gore," Patrick Leach's interweb essay on this subject. I've linked to the #13 discussion below, but if you scroll down to the bottom, you can find the links to the other models/numbers, too.
What you described sounds like it could be a #12-3/4, but it could be one of the transitional planes, too.
http://www.supertool.com/StanleyBG/stan3.htm#num13
Michael Brady
Don, from your description, it sounds like the plane is a #23 rather than a #13. To see if that is correct, follow the link shown in the other poster's response and look at Patrick Leach's reference to the Stanley Transitional planes, #'s 21 and up. The #23 was very common and parts should be fairly easy to find. Unfortunately, transitional planes are not very highly regarded as user planes.
Don Evans
Thank you both for replies, it is not a circular plane for sure.
I noted that all the planes on the one page I had time to look at were Stanley planes NOT Stanley Rule and Level. This plane was marked Stanley Rule and Level on the front end in the wood part of it.
I'll look further at this site when have more time tonight.
Don
Re: Stanley Rule and Level, Stanley, etc. *LINK*
Same company. "Stanley Rule and Level" implies that they're earlier planes (19th century). Stanley later simplified its logo. There are various "type studies" that can be used to estimate the production date of a plane; one, with visuals, is below.
http://www.rexmill.com/
