Shelf life of liquid hide glue-More from IWF
Bill Tindall
This stuff works so long as the protein molecules are not chopped up into smaller pieces by microbial or chemical reaction. If the microbes get at it it will smell bad. Chemical degradation can not be detected by smell but there are other tests that will detect any kind of degradation.
To be an effective adhesive the cured adhesive must be tough and strong. These properties result from the adhesive molecules, in this case protein, being very long such that the molecules can entangle with one another like a plate of mixed up spaghetti. Hence, a test to determine whether the molecules have gotten chopped into smaller pieces must test if the molecules are long enough to tangle.
Test 1 A common test is to rub some glue between thumb and finger until it begins to tack and then pull the thumb and finger apart. To be able to pull long "strings" the molecules must be tangled, so if the partially dry adhesive pulls strings it is ok to use. While this test is quick it is less sensitive than Test 2.
Test 2 This test is recommended by Franklin glue company. Dry a film of glue on some paper. When it is dry flex and pull the dried film. To be tough and flexible the molecules must not be degraded. If the film is tough and flexible so will the glue in the cured joint be tough and flexible. If the molecules are degraded the film will be brittle.
Test 3- When in doubt prepare a lap joint, cure it and bash it apart. If there is substantial wood failure then your technique and glue are good.
So how long can we expect the glue to remain usable? The advertised shelf life is one year. Stored cool the shelf life can be many years, according to a reliable source.
I tested some Franklin hide glue that was bought in 2009 and it tested just fine by Test 1 &2.
