New WoodChat!
Help with Spiers Infill needed
Ron in Kokomo
I cannot tighten my iron to the bed. The brass piece that holds the knurled screw is pivoting on two pins. I don't think it is supposed to be loose?
I tried to post a pic and failed.
Thanks for any help
Re: Help with Spiers Infill needed
Jim in Burlington Ont.
Jim in River Oaks, Ont.
Hi Ron,
Is the lever cap able to pivot on the pins without wobbling? Have you checked the threads on the hold down screw to make sure they are clean? With out a picture I am thinking you may have a loose pivot pin or debris under the iron.
Take care,
Jim
Ron in Kokomo
No wobble. But if it pivots at all, how can it hold? Do I need to delicately peen the pins?
Hi Ron,
There should only be two contact points with the lever cap, the right and left side via the pin (small screw in this image), the cap has two contact points with the iron, the large screw and the edge of the lever cap. I would not do a thing till you can show us a picture please.
Take care,
Jim
Ron in Kokomo
Jim the best I can do right now is e mail you a photo
Hi Ron,
Send it and I will post it for you my friend,
Take care,
Jim
Ron in Kokomo
I need your e mail address
The Picture is here...
Question for Ron *LINK*
Wiley Horne--So. Calif.
Hi Ron,
Beautiful plane! But not sure what is happening, even after looking at the photo Jim published. Yes, the lever cap is supposed to pivot.
I wonder do you have the correct iron and chip breaker? Attached is a link showing a Spiers NO. 7, complete with iron and chip breaker. Does your plane look like this, when it is all together?
Wiley
Infill Planes Showcase, showing Spiers No. 7
Re: Question for Ron
Hi Wiley,
I think he's missing the chip breaker, great link.
Take care,
Jim
Ron in Kokomo
Yes Wiley that is what I have
Ron in Kokomo
No Jim mine looks like what Wiley posted exactly
Let us try this
Ron in Kokomo
As you see, I do have the breaker. Yes I know it needs cleaned. When I tighten the screw, the brass piece pivots up and the screw is then not tight enough against the breaker to hold fast.
Getting closer
roninkokomo
At least you can see I have the iron and breaker, and that the breaker needs cleaned. BTW. This problem is very new. It used to work just peachy. :D
Better pic
roninkokomo
Note screw tightened all the way. Iron assembly still loose
Re: Better pic
Ron,
One of the lever cap pins must have sheared off. It used to work, now it doesn't, what else could have happened? If you remove the iron/chipbreaker assembly, and examine the lever's attachment, is there play in the lever cap's attachment to one side or the other of the plane's side?
Wiley
No play at all
roninkokomo
No movement side to side. Slow movement up and down or front to back
Re: No play at all
TomD
One thing is whether that is the right levercap for the plane. Is it possible an LC from another plane was combined to make a plane that is not original. Same relative to the bladeset, though normally there is less variance possible there.
Does the LC just rotate around the axis of the pin, there is no movement off that point on either side.
If so, how thick a blade would be required to get the LC you have to function within the middle of it's range. Try some shims just to know. Anything being held has to be under the forward end and the screw to be held, as you know. This would be basically a test of whether it is the right LC.
Re: No play at all
I'm wondering if Ron should try some shims, see if that works, and then permanently shim the bed for the iron with some appropriately fine hardwood, bringing the iron/breaker* closer to the lever cap and thus permitting the screw to clamp down before it runs out of travel.
*Chip curler? Can't recall what term we agreed upon :D
Re: No play at all
roninkokomo
Another question occurs.... Remember this plane worked fantastically well for the first five years I used it. I have been out of the shop for 9 years and recently decided to hone it to polish some cherry. What could have caused the change? And. The chip breaker is so far from the cutting edge... Can it be doing any good?
If I move it closer to the edge, it misses the screw.
Ron
One more complication
roninkokomo
The mouth is already extremely tight. Shimming will cause trouble. How about a longer screw?.
Re: Let us try this
GolfSteve in Calgary
Hi Ron, judging from the rusty imprint on the cap iron, it looks like the chip breaker used to be much lower in the plane than it is now.
Do you have the chip breaker in the right spot? I've never seen an infill in real life, but I think the lever cap should be riding on the chip breaker. It looks like you might have the lever cap riding on the plane blade because the chip breaker is set too high.
Just a wild guess.
Possible explanaton and solution
Hi Ron
It appears that all the attention has been focussed on the screw, that it may be too short. However, as you pointed out, the plane was used successfully for 5 years.
I suspect the problem lies at the other end. The lever cap is a fulcrum and the screw is one end of a lever. The other end is where the pressure is exterted, and this is too low for the screw. So, either the shape of the chipbreaker must change (create more if a bulge/dome - think of the Stanley chipbreaker), or the lever cap needs to be bent a little downward (which is an extreme solution - my money is on the chipbreaker).
A little more ..
Here is a picture of the blade and chipbreaker on the Spier I restored...
(incidentally, I am using an iPad - viz your other question - however I have copied this image from my website)
While this combination looks quite "normal"' I discovered in the resto that the chipbreaker was uneven in height, and that this affected the stability with which the blade was held by the leading edge of the lever cap. I hammered the chip breaker to an even height, and all has been well ever since.
The entry is at the end of the article (long):
http://www.inthewoodshop.com/ToolRestorations/Renovating%20an%20Infill%20Smoother1.html
