Goofy lathe question
Ron in Kokomo
Have any of you designed and built a treadle lathe tha uses a readily available v belt? If so, I would appreciate a few details.
Ron
Ron in Kokomo
Ron
Ron, that's not a good idea...
Joe shelton
...'cause if you run it on a V belt, you can't run it backward to put wood back on after a mistake. 'Course, you might be able to go to the far side of the bench.
Joe
Re: Goofy lathe question
Jerry Nicholson
A few years ago when I visited Don Weber's shop in Paint Lick Ky he showed me a lathe he had built using a bicycle chain and sprocket. I think one end of the chain was connected to the treadle and the other connected to a spring. Of course this would be strictly unidirectional.
Jerry
William Duffield
The only thing I don't understand about Don's lathe is why he doesn't use the bicycle frame for the pedal. It comes equipped with a perfectly good ball bearing joint (between the handlebars and front fork). It's a really ingenious, and green, solution to a problem in many economies.
Stephen Shepherd
Ron,
A V belt in that size may be difficult to find. Flat belts work well, you can use round leather belts like on sewing machines and they require a mechanical fastener like a staple.
A flat belt on pulleys that have slight bellies works great. The convex pulleys cause the belt to track to the highest point on the pulley, the center.
Stephen
TomD
V-belts have a high folding resistance which would significantly increase effort required to run them.
I think the bike lathe referred to is a design by Richard Star:
http://www.finewoodworking.com/SkillsAndTechniques/SkillsAndTechniquesPDF.aspx?id=33436
Plans are in his book woodworking with children, or something like that.
