Re: Nails
TomD
I like nailing frames together, it's like golf, physical, and you can slice and hook them. I have a collection of framing hammers. Modest though it is.
On furniture, the discussion is meaningless without context. I too have lived in a house were the kitchen was held together with nails, and it did not come apart. In fact, when we took down the upper corner assembly, that had hundreds of pounds of weight in it, it turned out to be held up with two framing nails, only. So let me try a few categories:
Heavy utilitarian furniture held together with nails;
Very light weight furniture held together with joints, because nails might not have sufficient bearing.
Furniture that has applied stuff like moldings held on with nails, these to cover the "fine" hand cut joinery. So "made with nails", but not avoiding joinery due to a skills shortage, or for other reasons.
Furniture that has hidden elements nailed in place. Could be dust panels, or drawer runners. Could be very strong.
Furniture that used nails somehow, and these were a basis for failure.
Bad repairs made with nails and hope.
Nails used without an understanding of their excellence in shear, and weakness in retention.
Etc...
Aesthetically...
There is a long standing practice of using design to elevate the quality of a piece. So a very simple piece like a Krenov might use no nails because it would drag the level of such a piece down. The aesthetic of revealed structure/exposed joinery is naturally going to lead to the idea that say dovetails are at a higher level than a nailed together crate. Because of the paradigm in play. A crate is pretty awesome if you love the structural cleverness of the nail.
A complex piece like a highboy might use nails to apply ornament, or even hide exposed joinery that would drag that piece down. The paradigm is different for this piece.
