We value your privacy.
So I need a real workbench and intend to build it, but I will use designs someone else came up with that I know work. One very popular one is the split top Roubo. It seems nice, but I can't for the life of me figure out why anyone would want the bench top split. What is the split for? Does it act like a vice? If so, how useful is a vice in the middle of the bench?
I haven't seen a split top Roubo. I did see a split top bench in PWW a year or 2 back.
Merit of the design? Bridging panels could alternately provide flat surfaces or tool trays, and the narrow dimensions of each half of the top would fit through a bench top planer.
I've seen this split top Roubo you're talking about and there is what appears to be a very thin split between the two parts. I can't see any benefit except in the building of it.
I built a split-top Roubo from the BenchCrafted plans 20 months ago.
Advantages: clamping through middle of the nench, easier to build, and much easier to move. The second point is important to me, as two or three times a year I take it to do WW demos. I can single-handedly move the STR, granted with some grunting.
Disadvantage: perhaps harder to flatten. At this point I can still flatten with shims when needed.
* 2 12" sections can fit through my lunchbox planer.
* I can probably handle a 12" section by myself
* There is the possibility of using two different species; i.e., hard maple for the front and poplar for the rear
* The split can be set up with removable, task specific tool holding modules
* Split can be used for clamping
* back side can be set to butt up against front side for panel planing and then moved back (not sure about the feasibility of this one.) Alternatively split can accept a module to provide continuous level surface.
* Bob Lang has found the split to be very useful for some sawing operations.
Since folks tend to like what they have/are used to, I hope there will be a real good and dispassionate analysis of the strengths & weaknesses of a split top.
I encourage you to think about using poplar for both the front and rear of the split top (or just a solid top of poplar for those building solid tops).
I had a massive 4" think hard maple top bench-- and I grew to dislike it. It is hard, crazy heavy, and more importantly -- slippery! My current bench is all poplar, and I love it. No issues with a slippery top, and it is more than stiff enough. With 8/4 as the top boards of a English style bench I'm quite sure I could park my truck on it without it moving. And a mortal can move the bench yet it stays in place in use.
Much better to dent a bench than the piece you are working on!
That said, my bench looks fine after nearly 2 years. And the construction lumber nicholsons we've built are holding up just fine after being abused (in and out of vans/trailers for demos) for several years.
Thanks for the input. Here are some pics of the split top Roubo:
There are some things I do and don't like about it, but I want to give the design a fair shake. I am really in love with the Lie Nielson Improved workbench found here:
I only wish it had round dog holes, which work better for holdfasts. I am pretty sure the only one who makes the perfect workbench for me is me.
I like the idea of making the bench out of poplar, mostly because I could build it with far less expense than hard maple which is important. Thanks for the input.
Bob Rozaieski has five episodes on his Logan Cabinet Shoppe video podcast, discussing work bench design and construction of a Nicholson (English) bench. This is the type of bench used at Colonial Williamsburg, and I believe used by Dean J and Mike Siemsen up in the frozen north woods. The Nicholson bench has a split top, and Bob discusses its use.
These episodes are well worth watching. Note that Bob uses only traditional hand tools in his woodworking.
