New WoodChat!
Pinching in saw kerf
Joe shelton
A piece of 1X pine, fresh from Lowes, gave me fits trying to make crosscuts. At first I was using a small circular saw, and the kerf closed down so tightly that the saw stopped. I had to work the opposite end of the board to finish what I needed.
The material was 1 X 12, and I fooled around with it when I could spare the time. A section at least 14 inches of this board will, when cut rip or x cut, close down so hard that none of my handsaws can cut more than four inches into it, and mostly less than that.
I've never seen this before. I've read of case hardening, but I thought that manifested in rips.
What causes this?
Re: Pinching in saw kerf
david weaver
Not sure what causes it that bad, other than tension and some moisture, but you can alleviate it by making yourself a few small wooden wedges to jam in the kerf past where you've already cut. One is usually enough.
David, I don't think so...
Joe shelton
...because I never got any blade far enough into the cut to get any clearance behind the blade.
Joe
Re: David, I don't think so...
david weaver
I've had wet 2x12s that I had to resort to a hardware store saw on, but they were never quite that bad. they did grip the plate even on the cheap saw, though.
How wet is it, if you took a chunk out of it and squeezed it with pliers, can you see water? That's what mine was like.
I guess more set is the only thing you can do - the endgrain can only move so far.
Or you can mark a line and work to it with an axe. :D
One other idea, if you're ripping it, do you have a bandsaw available?
Patrick Gibbons
Case hardening occurs when the outside is drier than the inside. I have experienced exactly what you've described many times, always a pine construction lumber of some sort. Boards like that are dangerous on power equipment and near impossible with hand tools. I have had this occur with boards that were inside my very hot garage (Houston heat) for years. I would have thought they would have evened out in the heat. If you can split them with a chisel or axe and them plane them flat they can possibly be shaped, otherwise discard them and use a new piece.
Patrick Gibbons
REread your post and see you're having the problem with xcut. One thing I have done is used a saw with a thicker plate and sawed down the cut line trying to widen the kerf. There were still boards that were destined for the junk heap.
Bill Tindall
The problem is obviously tension in the wood. The tension could be the result of too fast drying, but that is hard to do with pine. Or it could be a result of how the tree grew; I would guess the latter
Joe shelton
Bill, based on the articles I've read this afternoon, you're right, but I'm still confused. The problem in that section is, I'm convinced, reaction wood. My confusion arises from one article, from the U of Florida which says that reaction in conifers is compression, and tension in hardwoods. Maybe that makes sense, since the problem was across the grain, but I don't really get because I can't visualize where that board was in the tree.
Thanks for your comment.
Joe
Tension wood
Tension wood will cause the wood to act in crazy ways, yes. If that's what you've got, it's unlikely to be stable, and can do odd things like break across the grain; so this is not a piece of wood to make an heirloom piece of furniture from*.
If you must cut the wood for a project, you might try a relief cut - make a cut 1/4" or so away on the waste side until your saw binds, then catch up to that cut on the layout line, alternating between the two until you're done. Think of it as sawing practice, I guess...
*Some years back, I saw a little walnut side table on display in the window of a local store. Some tension wood in the middle of the top had begun to send up raised sections of grain - that part of the top looked like a really angry cat. Had it been my work, I'd have pulled the table instantly and decided to donate it to a charity shop or given it to some relative of whom I was not terribly fond or something.
