Re: Thought
TomD
The first thing I would labour over would be the batten. I rarely want a shallow parabola like that. I use deep ones a lot for boats, but long curves are normally arcs for the work I do, and I find parabolas with their pinched shape in the middle ugly in many cases. The solution if one wanted it would be to taper the ends so that the batten follows a curve. One would leave one side flat to follow the work and Contour the upper side, taking away about 1/2 the height of the batten. I think the progression is parabolic, but I may be wrong, it is relatively easy to just do it by eye, or match a curve.
However, there are better ways of drawing curves in my mind, and I tend to be very picky about curves as they figure in a lot of work I do. Boats, bows, and bowls are very curve picky. Bowls because that is the main design element. The same for boats, but also structurally, and really critically aero and hydro have to be right. With bows the right curve in the flexing of the bow is absolutely critical to performance and the look of the bow. So I'd get sick if I had to look at curves that were slap dash. I think there are quite a lot of woodworking activities with similar needs, so one leaves onself open to people with very picky eyes if one does not get the curves right. Of course the parabola is right in some cases also, but at the least I would want several battens to run different shapes with. That would be more sophisticated in my mind, than having a lot of fancy construction.
