New WoodChat!
Back to Woodworking- Card Table
Bill Tindall
Friend made this table in a class with Jeff Headley and Steve Hamilton. The friend makes all their Period furniture and one can see bits and pieces of it in the picture.
The table was going to be used (wild poker games?)and its owner wanted a durable finish. I sprayed it with a conversion varnish that provides good abrasion and water resistance. It was a cool morning so the finish flowed out perfectly without a hint of orange peel. I used 2 thin coats to provide a "close to the wood" appearance. The wood is stained with Bartley "Brown Mahogany" stain.
Re: Back to Woodworking- Card Table
david weaver
Fabulous piece. Really nice. It's a shame the internet can't communicate the same sense about the finish work as one can get in person with eyes and hands.
(speechless)
Now THAT'S What I'm Talkin about
Nice table.
Very nice table. Nicely finished too! What kind of sprayer did you use?
Tom
TomD
Nice look. Beware of the man with only one gun (that's a compliment just in case the reference is lost). Did you spray all the details also? Seems like that would cause a serious maintenance problem down the road. Possibly quite a long way down the road, though.
Inspiration
Bill Tindall
There are several people in my area that make this quality and complexity of furniture. It is quite inspirational. At least for me seeing someone make something of this quality encourages me to strive for similar quality and challenge, maybe not the same style but the similar quality and challenge.
The person that made the table is a good carver but there was carving on this table that was a stretch for what he had been doing. I think the concept of stretch is important for the amateur woodworker. I was late in grasping the idea but now each piece I make involves becoming functionally proficient in some new skill. Before long one can find themselves making stuff better than they can buy, or afford, as the case may be.
Stripping philosophy
Bill Tindall
I recently stripped, for the first time, a non-crosslinked finish. In this case it was nitrocellulose lacquer.
Comparing and contrasting- In the case of a cross linked finish, varnishes of any kind for example, the cured finish is one molecule and it is insoluble in anything. However the finish can be softened with this or that solvent mixture. Once softened it looses its adhesion to the wood and sheets of the cured finish can be peeled, scraped or rubbed off.
In the case of lacquer, and shellac I suppose, application of the stripping solvent makes a solution of the film former, which in the case of nitrocellulose is viscous and sticky like contact cement. Something with the properties of contact cement can't be readily rubbed, scraped or peeled off. It must be diluted to reduce the viscosity and blotted off, a tedious process. Based on this limited experience I would prefer to restore a varnish finish than a lacquer finish. I have no experience restoring shellac. A hundred years from now the Indians will be so rich that they won't be making it anymore. The few formal Period pieces I have made I did finish with shellac on the body and something more durable on the top.
Re: Inspiration
TomD
Absolutely, one thing you can say about Krenov is that he believed the amateur could set the standard. Of course it can also be otherwise. But I never started out believing I was working wood to lower standards than anyone else.
My only quibble about too much challenge is that it can bog people down. I think there can be ways of learning that are more productive than building a whole 2000 hour piece in order to learn the next skill in line. It can make the project grueling, depends a lot on personality. I generally believe the idea that you build your swing on the range, or with instruction, and you play your game on the course. There is a risk that if you are always stretching in performance that at some literal level you are teaching yourself to make mistakes. This comes across in music also. There are a lot of people who never learn to play even a simple piece without errors,but they may have a 99% of a masterpiece down.
I think a third piece in the puzzle is performance. One of the wisest articles I read was one about performance. Take your skills out in front of a crowd and put on a show. You will raise your game more in a few short days, or weeks than you may ever get if there isn't a performance to prepare for. That is why we have school concerts, it isn't so much for the joy of watching them.
Re: Stripping philosophy
TomD
Our only hope is that they will continue with the whole untouchables thing and there will be someone left to take the shellac.
I know with guitars, one way they are restored is to shoot them with more lacquer, and it just melts in and reunifies the underlying stuff. If it were me, I would do something on the base for all the carving, and something bartop like for the top where the poker is happening. The only thing about that is that often what they finished carvings with was not that nice. I just don't know enough, but from what I have heard they might mop on shellac, and it isn't going to come up as though it had been french polished. I don't know what they would do to pull off the detail gloss you have from shooting it.
By le way, what kind of varnish did you shoot?
Equipment used
Bill Tindall
DeVilbiss JGA 502 with 43 cap and 3M PPS cups. This is an ancient gun but it is so much more forgiving that the HVLP I bought, and no longer use. Son in law bought a 500 series on ebay for $50. The 3M cups are convenient and they enable spraying upside down and sideways.
Early in my woodworking I learned to spray. I have sprayed gallons of stuff over the years- shellac, lacquer, varnish, polyurethane, oil paint, conversion varnish. If I can spray it I do for the result is glass smooth.
Re: Equipment used
TomD
And fast.
Beautiful work, both cabinet and finish.
