We value your privacy.
So I got a wild hair, and decided to build a wooden plane. My initial intent was to make a dedicated shooting board plane, but then I went shopping for wood. I got a 3"x3"x36" piece of hard maple with perfectly straight grain, it was so cool that I decided to build a monster jointer plane inspired by one that Derek Cohen has on his website (see link). Being the naive young woodworker that I am, I still want to use this thing on a shooting board, so I am bedding the iron at 30 degrees, which was as low as I think I can go without compromising strength.
Using my steel hand planes, I got all four sides perfectly straight and perfectly square to each other. Then I drew on my cut lines.
It was when I went to start removing the waste that I had problems. I took my trusty chisel and mallet, set it in front of my line, and gave it a good whack....and watched my chisel cut in about 1/16". This stuff is HARD. Is there a better way to remove the waste wood? I really didn't want to cut the sides of the plane off, mostly because I have never had a good experience re-sawing. So I am at a loss, re-sawing the sides of would be the easiest way to do it, but it feels like I have to fight the bandsaw to do it (and I always lose). Could I use my panel saw? any suggestions would be helpful.
That said, if you go back and forth at your chip, your mortise will gain depth pretty quickly, and it'll actually be enjoyable.
Just be careful when you're doing anything (drilling, scraping, chiseling, sawing) that you don't overshoot your marking depths for the bed or on the escapement side. It's easy to do it, and depending on what you do, it might only be cosmetic.
Take special care not to cut yourself short where your abutments will be - think it through. I ruined two planes in a row mortising into where my abutments would be.
...by the way, I think you should stick with a one-piece plane for now. If i'm thinking wrong about the wedge and abutments, and you want to do your mortise straight sided and just use a cross pin and wedge or a lever cap, you can discard my comments about the abutments.
But at 3x3, you'll find things are pretty tight to get a 2 inch iron or a little more in a finished plane, and a plane of that length you'll want at least that.
a 4x4 blank is a bit more comfortable to start with, but I know as well as you do finding a blank of that size that's rift or quartersawn and isn't exorbitantly expensive is TOUGH to do. 3x3 blanks are out there for bats and table legs in droves, and don't cost too much.
This is why I always suggest getting a 2x4 stud to practice your chops on first, though so far nobody seems to have tried that.
What I would do is use your mortising machine to go through the mouth area from both sides. your mouth will be more than 1/4" so that is safe. You can then chop as David suggests, and it will come out a lot faster. Drill will do the same thing. However, when you are taking the correct size chips, you can just alternate and it will come out just as fast.
I think the LN plane is something like 45 skewed 20. That will be easier to cut than what you are planing, maybe. I little more difficult to lay out.
Also, you need a non-pansie chisel that will actually transfer a hit, and a big hammer. ear plugs.
