Re: an alternate opinion
TomD
It isn't always true that relying on the back panel means it was badly designed. I would argue the opposite in appropriate cases. Of course if the back needs a panel, then what about the front, in some case it has frames also. But anyway.
There are many pieces that are at a scale where weight is actually an issue, and they were designed with moving locations in mind. Today, we build a small fraction of the styles, and an even smaller fraction of the pieces within styles. But some of the pieces I saw as a child were extremely lightly built. While it is apples and oranges, I hold in mind the thought that trimarans up to around 40 feet, ocean going sailboats, use planking of the same type as is used in sock drawer bottoms. Today we vastly overbuilt.
And the other thing I have learned, having been brought up in boats and furniture to believe that glue was stronger than anything else, is that fasteners are required at times. Glue can start coming apart within 20 years with stuff like dowels, orther joints follow over time. A frame back is not dimensionally stable, it is highly stable, but not identical to the carcass, and it can work free over time. But screws will last indefinitely. There are cases were metal is an enemy of long term durability also.
The idea of screws from the inside is cool. For myself I am always patient enough to wait for the season, and then adjust the piece as required. But I guess one couldn't sell furniture like that. I have never used a pocket screw, but one of those from inside would also work.
I was joking about plywood. It would be hard to make by hand. I do vacuum bag my own for certain things. It is stronger than panels which is one of the original questions. But obviously it is not used in a lot of furniture, though there are molded plywood pieces of the highest quality.
