New WoodChat!
Anarchist Tool Chest
Texchappy
I'm a big fan of this book and really learned a lot from Schwarz from this and others. I have a couple of questions for the electronically gathered group:
1. Has anybody built one?
2. At one point of my learning curve would you reckon I could build one? (I get the feeling that this book assumes you're coming from power tools and have that experience)
Re: Anarchist Tool Chest
Chuck Nickerson
I'm currently working my hand tool set down to fit in two footlockers. (It's almost there.) I'm scheduled in August to take Chris' ATC class in Kentucky. After I'm done, I intend to restrict my HAND tool set to two chests. I like saws (20) and braces (6), so I'm not willing to go to just one chest.
If I could talk to my starting-out self, I'd really try to sell the idea of limiting myself to one or two chests. It might have kept me from trying to tool-buy my way out of skill deficiencies.
Building the chest will build your hand tool skills. If you're unhappy with the first, you can always build another later.
Curt Putnam
There are two major reasons that I won't be going the ATC route - as much as I like the book.
The 1st, and most important reason is that my back won't take the bending. While I can get down to within about 10" of the floor, the body complains enough for me to know not to do that very much.
The 2nd reason is that I'm unwilling to adopt the limited tool philosophy. I am still a blended w'worker and the toolset to which I want visible, quick reach capability exceeds a single chest.
Can you build one? There are two ways to answer that. Thee 1st answer is that only you an answer because only you know your skills and limitations. The other answer is: OF COURSE YOU CAN! We're talking wood here. What's the worst that can happen? You screw up a piece. So get another piece of wood and do that piece over.
David Barnett
(Message Deleted by Poster)
CStan
I haven't seen the specific plans but I believe they are probably beyond your skill level at the moment.
I still recommend the book Junior Woodworker by Charles Hayward and the building of the boxes presented therein. There is a small, dovetailed tool chest project in the book after you've knocked out some simpler stuff. If you can successfully build that little chest really the sky's the limit with regard to tool chests (excepting the ones with highly ornate, inlaid interiors).
I still think that you need to four-square the material necessary to build a small box/small chest and then nail the sucker together - plain butt joints. If you're feeling frisky you could try hand cut rebates but they are harder than they look. Point being is that I think you'll have your hands plenty full with four-squaring stock without adding a big joinery challenge on top of that.
Build a box out of lumber you processed by hand. Nail it together with a little craftsmanship and care (it'll easily last your lifetime) then move up to a more difficult project after that.
If you're not careful, you're going to end up with a lot of half done projects lying around the shop and a wallet considerably lighter for the cost of wood wasted.
How about a conformist cabinet then
Texchappy
Hmmm, you have good points. Was thinking more about a place to put my tools than my back. I've been worried about damaging or loosing things as they spread out on my workbench without a home.
I do like the idea of easy access on the walls better than a chest. One concern is I can't really mount anything into my crumbly 133 year old stone basement walls. :(
Hayward book in print?
Texchappy
I should say I'm not buying lumber for this right now, just wondering when but as has been pointed out that it's probably not the best form with my bad back.
I got an end 6 square to match my two sides. I'm waiting for my rip saw to get here to move on to the next.
Cstan, is the hayward book in print? I only found one used copy. I have Wearing's book. I think it takes you through a table. Would it be something to take on next?
David Barnett
Re: No need to hang it.
Texchappy
Gracias Senior Barnett,
Yeah, that'll work. I'll get the Toplin book when I get closer to being able to do that kind of work. I do believe my next project with be the straight-edge out of Toplin's New Traditional Woodworker.
Re: Hayward book in print?
CStan
Not in print... should be able to find it on Amazon, Alibris, et al.
You also need one by Hayward called "Carpentry for Beginners" knowing that the British term 'carpentry' also applies to furniture-making and that's entirely what this book is about. It has a nice tool chest project in it as well.
Get these two Hayward books. Read them. Build from them. They are totally free of bull$hit and except for the availability of very fine abrasives now for honing, not dated in any way IMO.
Derek's site
Ron in Kokomo
Go look at pictures of what Derek has done. Many of these ideas could be free standing or stacked
Re: Hayward book in print? *LINK*
Quite a few of the Hayward books are on Google books, see link below.
Turns out more than one person named Charles Hayward has been an author; you want Charles Harold Hayward. I'm not deeply familiar with his work, but many of those authors repeated themselves somewhat; so you might try downloading likely looking titles.
http://books.google.com/
Robin Corell in Atascadero CA
The best way to store your tools will depend largely on how you work. Some of this will be based on your personality and some will be inherited from your mentors. try not to get too attached to any particular idea and keep an open mind. when the time comes you will build what will work best for you.
Ive worked from a hanging cabinet with doors and I own a tools chest with a till, but I curently work from a pair of gerstner style boxes that sit on a narrow bench with about 12" of free space in front of each box. my chest sits on the floor under the bench and I use it for overflow and for tools I rarely use and dead haing to drag it out when I need to get into it.
Robin
CStan
Yep, that's the author although I did notice that while many titles are listed on Google the e-book is not available. All is not lost since clicking on the book brings up a bookseller that has a copy for sale.
Guillaume Dery
I've always had a fondness for Andy Rae's over the top tool cabinet myself :)
Curt, you don't have to bend over
Patrick Gibbons
One of the plans I have for a tool chest comes from a British source that provides for a stand, if desired. It elevates the chest to a comfortable height.
My experience
Patrick Gibbons
Texchappy,
I attempted to build a chest last year and made a major mistake on one side's dovetails. All's well that ends well. I had used southern yellow pine and have come to the conclusion that it's too heavy a wood for the intended purpose. I'll be attempting a build again soon and have decided to use either some white pine I already have or poplar which is very inexpensive in my market and available in wide, clear, stable boards. See my post below about stands.
Remember Anarchist
roninkokomo
Chris would tell you. Don't always follow my model. It may not be best for you.
Chris travels all over the world teaching and doing demos. He needs a chest to carry his tools around.? Do you
Chris is is pretty food physical shape and the bending is not a big deal for him. You?
Maybe a chest is NOT your answer.
Hayward
Patrick Gibbons
Check out Hayward's tool chest plan on www.toolemera.com/bkpdf/haywardhowtobk.pdf
This is the book that shows a stand for the chest.
Re: Curt, you don't have to bend over
Brian Anderson Gunsmith
Yet if you put the chest on a stand, why not build a cabinet.
No bending over. It requires a totally different design.
That design would naturally be capable of handling more tools because you would do it that way.
While I have found a tool chest design that I like way more than ATC, I am looking at designing a tool cabinet that can be moved. This part of Colorado is somewhat near forest fire area.
I am thinking along the lines of several smaller cabinets stacked on top of each other.
Hope being that each one could be simply closed up and carried away.
Re: Remember Anarchist
Interestingly enough, he has another chest not the ATC that he uses.
It has two trays, a simpler saw till at the front, and a chisel type rack on the back.
It is smaller.
bridger
Re: How about a conformist cabinet then
bridger
one very successful model of tool storage to consider is the automobile mechanics roll-away tool cabinet. lots of drawers, a top that can be used as a sharpening station or what have you, and wheels to make getting your tools to where you need them easy.
the arrangement of drawers on a factory made unit aren't bad for a woodworker, but don't hesitate to build one more suited to your own tooling setup. here's one of mine:
it's a pretty straightforward cabinetmaking project. it's not for carrying to a jobsite, however.
a practical approach
Bill Tindall
I made something similar, but substantially more ugly, for my lathe tools and accessories and found it to be quite handy.
What kind of runners?
bridger
Re: What kind of runners?
bridger
when I built this cabinet (back in the late '80s) I used some cheap cabinet runners I got for free. they had the disadvantage of dumping drawers when the sides flexed, as when rolling the cabinet around. I invested in some ball bearing drawer guides and am much happier with the result.
cabinet hardware may seem like a shortcut, like a "real" woodworker would make wood runners. in the case of a rolling tool cabinet, consider:
* weight is an issue. it's gonna be heavy when full of tools. you will want to roll it around. a wood runner carcase is heavier than a euro cabinet carcase.
* full extension of the drawers is a good thing.
* ball bearing guides are easy to adjust and don't tend to wear like wood runners on a drawer full of heavy tools.
