New WoodChat!
Sunday satisfaction
Sunday satisfaction
Sunday satisfaction
Stuart Hough
Got the short stretchers attached to the workbench legs Friday...drilled the holes and pegged them tonite. As I said before, I'm not sure it was necessary because of the really large glue surface on the tenons, but it was one more lesson learned, and they will look great when I put the finish on. Bolted the long stretchers to the legs, also. I previously had drilled the stretchers and legs for threaded rod, washers and nuts, a la the bed bolt style of attachment. Once I finished tightening the bolts I checked for square. After one year of fiddling with the base, I have it to within 1/64" of perfect! I am almost beside myself with joy, because this is the first project of this size I have ever done, and it's coming together really well! Next thing is to put the top upside down on a piece of carpet and turn the base over and set it on the top so I can mark out the mortices for the leg tenons, and lay out for the end vise. Any advice will be appreciated on the best way to mount the vice, an old Columbian quick-release model I believe is from the 40's. Till the next update.......
Re: Sunday satisfaction
Jack Guzman from Maine
perfection
Stuart,I got the same feeling when a seemingly difficult operation comes off perfectly. My first thought was that I got lucky . However,on thinking it through I realized that I was just paying more attention to small details. Being precise with all the little steps brings perfection in the end. It still feels like magic to me though.---Jack
roger lance
Stuart....Congratulations on your progress!!....sounds like things are coming together beautifully....I use to have hair that was thicker than 1/64"....there was a section in "The Workbench Book" by S. Landis on setting a Record vise that might be helpful for mounting ideas....good luck....look forward to seeing your bench!
Ron in Kokomo
While it has been a long time since I had hair thicker than 1/64 th, I too salute your progress. What fun photos soon?
Ron
Stuart Hough
Thanks for the advice and kind thoughts. While I have been acutely aware of the "little steps" I needed to take, I believe it's been much more luck than skill. I broke a lot of rules on the way, and still everything works! I will get the Landis book and check out the article on the vise. I appreciate the support!
