New WoodChat!
Moxon vise....weekend progress
roger lance
Well its not big time woodworking....but during the summer, my ww turns to the exterior of my house with little time in the shop....so this Moxon will have to do....and here is a progress pic of the vise so far:
Derek....I'm thinking of beveling that front chop as I don't see it as a problem....all I'd have to do is rotate the chop and I'd have a full level base for registering a chisel??!! I really like the Benchcrafted hardware....I just basically followed their suggested vise construction and altered the design so that it can be held on the bench between dogs or clamped to the front of the bench and also fit in the space in my shop reserved for the vise when stored. Some sanding and a finish to follow.
Re: Moxon vise....weekend progress
Steve Corpstein
Very nice Roger, it's obvious you're up to another fine example of woodworking. The bench it's sitting on looks good, is that a recent addition to your shop?
roger lance
Steve....thank you....the bench is about 15 - 20 years old now (I buried a made on date plate inside the bench....but it takes a little to get to it)....heres another pic of the bench (which is probably the best thing I've made in terms of the creativity of the construction)....
Guillaume Dery
Roger, I find that the time you take and attention to detail even for mundane shop projects quite inspiring. The transition from the base to the upright and the rounding of all corners of the chop are proof that you always take the time to do the job right, even if it's jsut for yourself.
Unfortunately, I can't claim to have to same cumpunction but seeing the result is starting to prod me in the right direction.
Guillaume
roger lance
Guillaume....my father was an old school German home builder and I grow up working with him where straight, square, plumb, solid, and doing your best were the order of the day....his schooling had its effect....and I thank him for it.
TomD
I'm not sure about that... It is the graceful curves that run together, and seem to add to a sense of strength.
roger lance
Tom....curves can be old school... :D :
That's nice work
Ron in Kokomo
Have not started mine yet. Worked outside yesterday. Kinda lazy today. Went to church and then listened to Indy 500. You are setting the bar pretty high.
Ron a Kokomo Galoot
Design note on the Moxon....
roger lance
I've been doing a lot of lurking on various forums....reading threads on Moxons....and I know I saw Derek Cohen's design several times and followed some discussions he had with people about Moxon features....so his influence is all over this vise....chicken or egg??....we get inspiration and we inspire.
Hi Roger
Try it and see if it works for you. After all it is just wood and easy to remake.
I wrote a reason why I do not do so here: http://www.inthewoodshop.com/ShopMadeTools/ModsfortheMoxon.html
roger lance
Having one edge beveled for sawing....and the other edge square for chiseling....don't know what I'm missing here.
Hi Roger
Possibly missing nothing ... it depends on the thickness of the chop, and I am sure that the BC wheels spin on-and-off quickly - my wooden threads are likely to crawl by comparison. I could not consider reversing the chop, as you plan. So for me it is KIS. Let us know how it works out.
roger lance
Derek....the ability to quickly change over from one configuration to another is a definite factor to be considered if something should or should not be modified.....like so many other tools/jigs, I plan to use this one for awhile before making any additions/alterations....that experience of use thing is so valuable.
