New WoodChat!
Militec-1
Militec-1
Militec-1
eliot d
Has anyone heard of it? I ask because David Barnett suggested Dialube - or something similar -- for use on the LV diamond films. Would this stuff work? It's called a "Synthetic Based Metal Conditioner ". Can't remember why I got it, but it's supposed to be special snake oil. What kind of places sell Dialube?
Re: Militec-1
On a parallel issue ..
Hi Eliot
Take note that the best lubricant for diamond film or diamond stones may suit metalworkers but not woodworkers. I have no knowledge of the "snake oil" that David recommends - and cannot comment of that specific tonic - but take note that he is working with precious and semi-precious stones. The question that must be asked is whether the oil will affect the wood if it finds its way to it, such as when the finish is applied. One of the reasons I chose Camillia Oil was that it is finish friendly.
Re: Militec-1
Dialube
John in NM
No clue if the stuff is similar, but dialube is readily available from lapidary suppliers, which are virtually all mail order outfits. I'm a bit rusty on who's who any more, but you could try Graves and maybe Kingsley North.
Re: Militec-1
A good point....
John in NM
I believe most of the diamond lubes (also called "extender fluid") are some form of silicone oil, and might end up being problematic. I've always been highly skeptical of the dangers of silicone transfer from a plane or blade to the wood in any kind of quantity, but there is the very real danger of splashes and spills and most probably transfer via your hands. Any time I use a silicone lube it seems to take a lot of washing to remove it from my hands.
Re: Militec-1
David Barnett
All Dialubes not the same
David Barnett
Graves and other lapidary suppliers usually offer Dia-lube 20, whereas I recommended Dialube 3000, specifically designed for diamond films. Although Dialube 3000 is formulated for coarser diamond mesh films, it also works well for finishing tool steels on the finer films. Dialube 3000 is a glycerin-based lubricant-extender, can be cleaned with soap and water and contains no silicones. My uses for diamond films are more for optical/metallographic than lapidary, by the way. Diamond charged BATT and ceramic laps leaver flatter facets with sharper edges than films.
The name can be confusing, John. In fact, one Dialube on the market is a suspension that actually contains diamonds. The Dialube I was referring to can be purchased from Pace Technologies.
While I would never recommend a silicone product for woodworking, even with a silicone-bearing lubricant you'd likely have to spill or spray it directly on the wood to cause finishing problems. Wiping the blade should mitigate sufficient transfer.
Re: Militec-1
David Barnett
I wouldn't think it's at all similar *LINK*
David Barnett
I wouldn't have any idea how a "Synthetic Based Metal Conditioner" would relate to diamond sharpening films. Camellia oil is fine, as Derek points out, can be found in some home shops, and easily ordered from nearly any online woodworking supplier. Try whatever lubricant you have handy and see if that works for you. If you go through the film sheets too quickly, and you're sure you're not using a heavy hand, then perhaps try something else.
Pace Technologies
Re: Militec-1
I'll admit...
John in NM
The whole lube question is a bit esoteric to me, I haven't used much but wd-40 on diamond laps in years. But then I was always more of a commercially oriented cutter, keep it all cheap, fast, and simple. No one would pay $50 to have a chip taken out of a $40 stone, so it pays to figure out how to do it for $10 - then even the cheap guys will go for it :D
The only reason I replied at all is to suggest a supplier - and after checking my usual supplier's site, he doesn't even carry dialubes... oh well :D
Re: Militec-1
Re: Militec-1
Michael Brady
I have used Militec as a metal lubricant, but wouldn't use it around wood that has yet to be finished. It is just another synthetic oil sold in very small bottles for very big prices. It might have cured the M-16 jammng problems, but that's a far cry from lapping film wearing out.
Re: Militec-1
Re: Militec-1
eliot d
I suppose I figured as much. I don't know what to do with this stuff. I have the impression that it penetrates metals very well, so I sometimes rub it on my lathe bed. Doesn't seem to hurt it. Can you suggest any uses; I have a fair amount of it.
Re: Militec-1
Re: Militec-1
Michael Brady
I think the best common use for Militec would be as a bicycle chain lubricant. It can be applied and then wiped off, which is ideal for the application. Garden tools would be another area. It was supposedly developed as a gun oil, but view those claims with healthy skepticism.
Re: Militec-1
Re: A good point....
Guillaume Dery
Dinna be skeptical laddie!
I can absolutely guarantee that it can and does happen and has some rather spectacular effects on the finishing process. I have had a very nice table almost ruined by it. I kept getting what I refer to as aligator skin on both lacquer and shellac.
Since it was an ebonized finish, my last resort (which worked) was to sand it back, seal it with an automotive sandable primer, sanded again and used lacquer paint as a spray finish. Not as nice as the finish I was originally planning but it did save the piece.
There were no spills in the shop but I did have a spray lube that contained silicone. So either overspray when working on a machine or accidentally getting some on one of my cutting tools (chisels and/or planes) were the only possible culprits.
Guillaume
Re: Militec-1
TomD
I gather some sandpapers themselves have no clog components that affect finishes. Never had the problem, just read about it. I also worry about the effect of silicon on electrical components, though my cat seemed to like it.
