Re: Having a hard time with my wood plane
TomD
+1 with Craig on that. I always put a little wall there, or a return. The reason is that if the plane actually sees some serious wear, then the mouth will not open if the sole is reduced in thickness. So as said it should not cause any difficulty. I don't doubt one could evolve a geometry where this was a problem, some combination, but it would not be typical. Also, even with a "wall" you can polish if up smooth, wax, it, round over any sharp corners (othert than the mouth/sole itself)
The most common Krenov fault is the position of the crosspin, or it's dimensions. One really has to standardize these details from the book, or a successful model. I have two gauges, a taper that represents the wedge, and a parallel piece that represents the gape between the pin and the ramp. The pin needs to be correctly dimensions, located the correct height above the sole, the correct space for the ramp/blade combo. I realize you mentioned everything was identical, but I have seen this get away from people. I have been making these and teaching them since the late 70s.
Can you watch the plane from the top and see where the shavings are holding up?
The way Krenov actually showed making planes in his book was that when establishing the position of the parts prior to glue-up, he would hold the blade about 1/8 above the sole while lying on the ramp. Then he would close the angled mouth block till it touched the blade. The result is that the mouth actually starts under the point of the blade. So by the time the mouth is filed open enough to take a shaving, the angle above the mouth will be quite a bit steeper than the primary angle. Not a "wall", but getting closer to one than the primary angle would suggest.
I hate to mark a book, but the mouth angle was not given in my Krenov book, so I gently drew in some lines and measured it. The mouth was 72 degrees, so with the opening he did the "wall" of the mouth would be steeper still. Pretty close to where you are.
Over the years, I have come to prefer a plane with a vertical mouth, and much lower angled primary angle, but the original format does work. I did notice, though, in the Krenov plane making video, that the operators at the school, filmed in the video, have to use their fingers to clear the plane cavity with virtually every pass, which suggests a bad design.
