When dovetailing, how many cutting gauges
roger lance
do you use?? Decided to make good on my intention to make some cutting gauges for hand made dovetail use. These gauges will be simple simon and I'll post a photo, but how many to make??
roger lance
Re: When dovetailing, how many cutting gauges
Sgian Dubh
Two or three should generally be more than enough I'd think. For example, if you are cutting drawer dovetails, you'd use one cutting gauge to mark the length of the tails at the front of the drawer side; the same setting of that gauge is used to mark the end grain of the drawer front into which the tails fit.
At the back end of the drawer, the drawer side and drawer back are usually, but not always, made of material that's of equal thickness. Therefore another cutting gauge set to the thickness of this material should be all that's needed to define the length of both tails and pins.
That's two cutting gauges. If you're into making these gauges then, as I said at the beginning, two or three should generally do all you need comfortably. Slainte.
Pam Niedermayer
I use one to mark the board thickness/bottom line. That's it.
Pam
The Will Neptune knife gauge
Bill Tindall
Will spoke at length about the advantages of his making gauge/knife and indeed demonstrated its advantages numerous times during class. Its unique features are its narrow round beam (a flattened dowel) which provides better visibility than the traditional stout rectangular beams and a tiny double bevel point which provides deep penetration of the scribed line, much like the superior Blue Spruce marking knife. In one example Will was paring a tenon and the shine from the face of the scribed line was plainly visible as the paring approached this line.
The dowel is flattened on its top and a thumb screw passing through a threaded insert presses against a brass shoe that in turn locks the dowel in place.
PS
Bill Tindall
Will only used one to make about any joint one can imagine for case pieces, tables and chairs. On occasion I have found that two are handy. Indeed if the cost is moderate I would make two. He was so quick at adjusting his gauge (by tapping into adjustment like a wooden plane wedge) that he could get by with one.
Re: The Will Neptune knife gauge
roger lance
Bill....Welcome back....hope you had a great time at Will Neptune's school....two gauges it is.
Hi Roger
You only need one ...
OK, if you are using a powered thicknesser (planer), then you can get away with 2 (if marking through dovetails) or 3 (if marking half-blinds).
If you are hand thicknessing, then you may need one gauge per end.
My preference is a cutting gauge since a true knife edge creates a cleaner and, when wanted, deeper line. The wheel gauges offer a lot of control, but the down side is a light line.
Here is one I made several years ago ..
My favourite is a Kinshiro (which is a mortice gauge, but can be used with one cutter) ..
Pam Niedermayer
Agree completely with the Kinshiro gauge, great tool. If the two sides of a dovetail joint are the same width, I only use one gauge; but if not, I usually use two. Or, the only mark I make is for the bottom line to which I cut/chop/etc.
Pam
roger lance
Derek....I think I'll order that first one from LV on April 1st
david charlesworth
It has to be three !!
One day you might like to try a scret mitre dovetail, or do you call it full blind over there?
It is good practice to preserve your gauge settings, as this allows you to freshen up a line if it gets compressed a little, during the work.
Best wishes,
David Charlesworth
roger lance
Mr. Charlesworth....glad to hear that you are doing well....full blinds are above my pay grade at this juncture....but a third gauge will not be difficult to make if needed....God bless.
TomD
Normally I use one. But it is partly due to the fact that I have one preferred gage. This particular gage is very good at picking up lines within the degree of error, so it is no problem to have a single gage.
Welcome back David
Ian (in Sydney, Australia)
it's great to see your name appearing again in these forums
best wishes
Ian
Thank you Ian
