New Lee Valley Chisels??
tony roth
Wondering if anyone has any information on when Rob's new chisels will be available? Thanks, tony.
tony roth
Rob Lee and The Shadow do.....
roger lance
but neither one is saying.
Re: New Lee Valley Chisels??
Rob Lee
Hi Tony -
The O1 chisels are ready.... it's the handles we're still futzing with. The caremelised maple has a bit of an unanticipated learning curve, and it's taken awhile to get the turning and finishing processes correct. We approved the first pre-production batch about a week ago.
Also last week, we received our first batch of PM-V11.... so work on those chisels (and plane blades) will start soon.
I'd like to be able to telegraph the price and availability date for the PM-V11 chisels at the same time we release the O1 (so customers can make an informed choice) so that may hold them back just a tad longer too.
Cheers -
Rob
Howard Pollack
Rob- Can you say something about PM-V11 steel? It is one of the millions of steel I know nothing about. Thanks -Howard
Re: Maple causing trouble?
david weaver
Maple problems? No problem, just use olivewood instead
That'd put a bit of a wrinkle in material cost, though, huh?
Rob Lee
Hi Howard,
PM-V11 is a proprietary powder metallurgy steel, made in USA. It is the steel we chose for plane blades and some chisels after extensive testing - against dozens of other likely candidates. We evaluated all steels for a number of use and maintenance characteristics, and scored each - plotting a performance evelope of the steel characteristics.
We will be publishing much of what we found on the PM-V11 website (which has only a placeholder page at the moment).
In a nutshell - it's as easy to maintain as A2, holds an edge at least twice as long as A2 (and at lower bevel angles) - and affords excellent impact resistance.
It's a very impressive steel. Some of the other steel that were candidates were CPM-3V, CPM-9V, and a PM M4. We also looked at PM M2, A2, and D2 steels. PM-V11 outscored all of 'em.
Cheers -
Rob
Rob Lee
Yeah - it's the 0% moisture content that makes it tough to work with in a production envrionment.
We're trying to work to a cost target (after all - it's your (figuratively) money we're spending) and that means a degree of volume and automation. Hand processes really start to add up ...
Cheers -
Rob
Caramelized maple? Sounds tasty.
Tony roth
Thanks Rob for the transparency!
I also appreciate the very thoughtful approach for releasing the information, especially since I am particularly interested in the pmv chisels. If you could kindly let us know on this thread when you determine release time for this info that would be much appreciated so we'd all be sure not to miss it!
Best,
Tony
wilbur
Do you need to use diamonds to sharpen PM-V11? Or will other methods work?
david weaver
Proprietary as in only Veritas? Or Proprietary as in only one maker can make it but anyone can get it (not that I'm trying to get raw stock of anything I can't harden in the back yard).
Is it similar to A11 steel?
Rob Lee
Hi David -
Proprietary as in only one maker can make it. That's as far as I'll go....!
No - it's not A11 (CPM-10V)...
Cheers -
Rob
A Peek for Tony... *LINK*
Rob Lee
Hi Tony -
Here's a peek - got 'em yesterday afternoon....
Cheers -
Rob
O1 Chisels
Can anyone else peek?
Jack Guzman from Maine
Rob,
Any bigger sizes in the makings? Those are beautiful chisels. It's hard to find a decent 2" chisel that isn't a foot long.---Jack
Re: Can anyone else peek?
Rob Lee
Hi Jack -
We'll be going wider with the Butt chisels... to 2".
Cheers -
Rob
Those look great!
John in NM
I've been holding off on replacing my Sandviks, cheapskate that I am... but I believe I'll try some of those when the fancy steel ones are available
Re: A Peek for Tony...
Tony Roth
Thanks Rob! Can we assume the m2's will look identical, perhaps a slightly different tone to the steel? Ill definitely be waiting for those...Tony
Rob Lee
Hi Tony -
The PM-V11 steel chisels will have the same design....
Cheers -
Rob
I appreciated the opportunity to peek
Bill Tindall
......with the expected result that I have mailed this link to many others that don't frequent WoodCentral.
