New WoodChat!
Continuous arm Windsor
Jack Guzman from Maine
This is a practice chair. I built it to learn all the processes involved. It is a complex process with many new skills to master. I really need to work on my turning. Those leg profiles were made presentable with sandpaper. I love carving the seat blank. Getting all the angles right is the most difficult part for me.
I just started carving a new seat blank for the first keeper.
I would love to go to Michael Dunbar's windsor school but it won't happen in my lifetime,so I got my lessons out of books. Alot of trial and error involved. Curtis Buchanan's videos sure came in handy.
Thanks for looking---Jack
Re: Continuous arm Windsor
Lovely. Continuous arm Windsors are amazing chairs - that complex, three-dimensional bend just seems like it'd be hard to conjure out of a stick and thin air.
Nice job
ron in kokomo
Made one a few years ago. Your first one is better than mine.
Hank Knight
Jack,
That's a great looking chair! Continuous arm Windsors are my favorite style. Nice job. I can't wait to see your first "keeper."
Hank
Nice!
John in NM
Did you bend the back?
I can sympathize with the turning, I do a bit more with sandpaper or a file than is really right :D A few catches at the wrong time and I just get too jumpy to do anything else.
Very nice chair!
Chuck Nickerson
Having built a sack-back Windsor in a class, I can imagine the effort that went into the chair.
Steam bent
Yes, I bent that piece using steam. It's alot simpler than it looks.---Jack
Re: Very nice chair!
Thanks. Once I get this one right,a sack back is my next effort.---Jack
I love that part. Steam bending is kind of magical.---Thanks---Jack
Re: Nice job
Thanks but actually,this isn't my first chair. My first one was a comb back and it is a funny looking chair. Crooked in every way possible.---Jack
I like this style especially myself. Thanks for the kind word.---Jack
Pretty darn good for a practice chair
Bruce, a MN Galoot
Heck, it's pretty darn good for a keeper! Very nice job, Jack.
A bunch of years ago I made a continuous arm Windsor in the style of Thomas Moser, with a laminated continuous arm. After that experience, I would imagine a steam-bent arm is much easier. You did a really nice job on that.
I am curious, though, what about this chair makes it not a keeper? I understand building one for practice, but what refinements do you think it needs? I'm not seeing it.
BTW, will this one be painted?
Re: Pretty darn good for a practice chair
It looks good because I did a good job of covering up the screwups. What really sinks it as a keeper though is the arm posts. When I drilled them,I didn't lean them out far enough and you have to be skinny to sit in it. Otherwise it's not really bad. I realized the arms were wrong early on but there was no practical way to correct it. So from that point on it was a "practice chair".I love the way it feels,it fits me perfect,so it's now my new shop chair. Yes I am going to paint it. I'm experimenting with milk paints and I'll cover the paint with BLO.thanks---Jack
Re: Steam bent
Greg Betit
I think you're being too humble. Working that crest/arm piece while straight, imagining which part will end up oriented which way after the 2 dimension bending is for me a real brain teaser, and I have class notes to go by! Then getting the material steamed just right and bent along the forms just the speed and way they need to be without issues is another hurdle. I usually make 3 blanks to steam just so's I'll have one good enough to be a part of a chair. It doesn't always take that many, but walking away without any usable parts really takes the wind out of your sails! DAMHIKT.
greg
Ron in Sterling, CT
Excellent job Jack. There aren't many shops around with a shop chair of that caliber.
Ron
Pam Niedermayer
Looks great to me, beautiful work, Jack. Did the too closely placed arms result from a combination of the bending and support, or was the support sufficiently powerful to squeeze the arms?
Pam
The arm is flexible.If the posts were at the correct angle the arms would easily bend to fit. Also that angle is adjustable with a little applied heat .---Jack
Thank you.
I see, thanks.
Bruce, a MN Galoot
When I made that Moseresque chair, I found it necessary to make a jig to drill the spindle holes in the seat. The rail/arm was only 1-1/8" thick (oval shaped) but it had very little flexibility. It would be nigh until impossible to drill those holes by eye. Ya done good!
Look at the positive side
It'll encourage you to keep weight off.
Re: Look at the positive side
:D I never thought of that. It'll keep oversize people from breaking my chair too.---Jack
Re: Cheater-Boots way of turning
TomD
If you want an easy way to clean up your best efforts turning that will leave you with a bigger halo than sandpaper, is probably easier, and certainly faster, and allow you to cut crisp details... Set your rest at a height such that a skew, flat on the rest like a scraper, can be tipped so the top bevel is pretty near parallel to the floor, and the edge is at a height that is near the middle of the piece. If the edge were below the median it would tend not to cut. However, if it is too high, it could catch. Just gently stroke the surface with the edge and you will get fine shavings, and leave a very clean surface. You will still want to do a very light final sanding, to blend the surface textures of your various tools. The best skew of this kind of work is one with a convex edge, like Raffan has described in his various books. I like a long point and quite an obvious convexity. Some of the Raffan skews in the catalogs are pretty subtle.
Skews are cursed
They do such a fine job when all goes well but one slip and you're done.I got a run of confidence after watching Curtis Buchanan in his videos on chairmaking.He doesn't sand at all. This lasted just until I destroyed a leg with one little slip. I'm going to try your tip but not on an almost finished leg.
I do most of my turning with a 1" roughing gouge.I keep it good and sharp.I practice with the skew alot but I still don't trust it.---Jack
