New WoodChat!
The phoenix has arisen - bench progress
Well I guess it not quite a Phoenix, but the bench build was in threat when I left off at the last report.
I had reached this point ... the top was looking good, and I was ready to assemble the base.
And then Perry, my ex-friend, discovered that I had inserted the dog strip back-to-front! Bugger. Looking through old photos I realised that the dry run had them the correct way, and I had marked them for the glue-up ... and then misread my markings. Bugger again.
A repair was complicated by the fact that the dogs angled 2 degrees ... now in the opposite direction!
Many on the forums recommended that the best way to deal with this was either to fill in the dogs and drill them for dowels, or to try and insert a shim and re-chisel the dog angle. It struck me that few were willing to start again - to cut out the dog hole strip and re-make it. Modifications as repairs are rarely satisfying. It is far better to have the Real Thing, even if this means pushing the envelope to do so.
Reshaping the dogholes is not practical. It is not just that they slope at 2 degees on both sides of the shaft, but that the head of the dog faces the wrong direction. Even if you turn this around, the support for the dog hole head is now absent. I don't want patches.
The plan was to remove only the dog hole strip as far as the last dog hole. There is no need to touch the side board or the area for the tail vise, and the latter includes leaving the dovetail well alone.
I must say a big Thank You to Perry who came over this weekend to help. I really could not have done this without him. The bench was rotated several times. Most importantly, Perry made sure I did not get anything back-to-front! :)
The main working tool here was a powered router. A series of guides were built to use with a bearing bit. The sides were deepened in a progressive manner, working to a few mm of the final dimension for the dog hole strip.
Top ..
Bottom ..
... keeping well away from the tail vise area ..
I had managed to beg another 4"x2" board in European Oak, and this was turned into a new dog strip with dogs 3" apart. This was an upgrade on the previous dog hole strip, where I joined pieces together having run out of this wood. It had look OK, but there were joins if one looked carefully. Now the strip was one continuous piece.
Checking that the strip ran in the correct direction!!!
A temporary planing stop while I fine tuned the insert ...
Here we are, glued up, the strip a little proud of the bench ... Perry looking on. Thanks again Perry.
That was Sunday night. I finished work today and had a few hours free. The first thing I did was plane the raised strip flush with the bench ...
Even with a close inspection it was not possible to see that there had been a repair.
I am delighted with the way it turned out. On a high I decided to nail together the base.
While preparing to draw-bore the stretchers into the legs ...
... a novel way of inserting the draw-bore pins occurred to me. I ran the pins through my pencil sharpener ...
to taper the ends ...
After a coat of oil the base ended up like this (I must point out that the flash does accentuate the figure) ...
One detail for now - the sliding deadman lower guide. This is screwed on to the stretcher. The idea is that I will not have to lift the deadman over it (when fitting the deadman), and this should translate into a fit with closer tolerances) ...
Next weekend I should finish the bench. Just the leg vise and deadman to complete (80% done) and the tail vise to screw on. Then the dogs to machine. The shelf has to be made. And a few other odds-and-ends.
Re: The phoenix has arisen - bench progress
Great Save!
Exhale!!
What a relief. Looking real good.
Nice save
McKay
You have mentioned how difficult Jarrah is to work with, but MAN what beautiful stuff it is!
Ecxellent!
Great job on the repair!
Re: Nice!
TomD
Probably a good tip for gluing up to have a dog fitted, or some scrap, to indicate direction, as appears to be the case in one of your photos. Or a single dowel to align in the correct direction so it can't go together wrong.
I don't know that you ever quite got the geometry of the kudgy repair, since the dog hole overhang/ would not have been a problem, but is actually an advantage because it provides meat to set the chisel in, and general working room. It was necesarry to an appropriate repair.
Also I don't know that people wanted you to make a kludge, but what is there to say about a do over? You pretty much know that route already.
clever
Jim in Burlington Ont.
Pencil Sharpener
Jim in Burlington ON
Nice Bench. I put my pencil sharpener on the ceiling right above the vice end of the bench. Leaves it clear for sheet goods.
The high road
I'm glad you took it, Derek. Good call.
What I can't understand is how you routed out a cubic meter of sawdust and not a fleck of it is in evidence anywhere. You must spend half your time vacuuming the floor. :)
Thanks for an excellent update.
Backwards Coriolis effect
James Watriss
In the southern hemisphere, the dust doesn't land on everything like it does up here.
You're saying that...
...if Derek had included a shot of the ceiling, it'd be up there?
I betcha...
John in NM
He wore his polyester lesiure suit for routing and all the dust stuck to it :D :D :D
Re: You're saying that...
James Watriss
Yes.
Yes, I am.
It's a very misunderstood aspect of gravity, you see... it's actually just a vector in the general direction of 'south,' along the axis of rotation. That heads into the globe for those of us who are far enough north, but literally falls off and away from the planet in the southern regions, thus explaining the dust and shavings on Derek's ceiling. Contrary to popular belief, the British really thought they were just throwing their criminals off of the planet.
This driving force has gone so far over the centuries as to pull all of the land that way... which is why the north pole is just an ice cap, with no actual land underneath it, and Antarctica is so huge. It's also the reason that there are so many dense, hard woods in Australia: Due to their density and weight, they were all pulled in a roughly southern direction, while we up here in North America were left to be overrun with sugar pine, and China's covered in bamboo: it all just floated up that way.
I'm pretty sure this piece of long-forgotten knowledge surfaced in one of Ellis' Grandpa Augustus stories. Tried though they might, no matter what side of the tree they started to cut, if the tree was on flat ground, all other things being equal, it always fell to the south. That's why land-lubber compasses evolved to point in a northerly direction: Come lunchtime, when the sun was high in the sky, it was hard to tell which way was north, and which way was south. So, they put those little arrows on their compasses, to indicate which side of the tree to stand on when it was falling. Eventually they realized that the trees on the side of a mountain would fall downhill, due to ambient leverage, eliminating the need for compasses, and it's why the logging industry eventually migrated to the Pacific Northwest.
It's all so simple
Bruce, a MN Galoot
when you explain it like that. Should have been obvious! :D
