New WoodChat!
Sharpening station drawer question....
roger lance
If I built the carcass as first proposed, the drawers would be about 34" wide. Is that too wide for a shop drawer?? All drawers will be on 100lb full extension slides. But would two 17" drawers be a better design choice as opposed to one wide drawer?? The total proposed height of the drawers is 21"....so three drawers of 4",7", & 10"....or some other combination of heights would fill this dimension. Thanks again.
Re: Sharpening station drawer question....
Hi Roger
I'd go for 2 smaller drawers, even 3 if you can fit them (they do not need to be the same widths). Less clutter and easier finding of items.
Depends
I might do a 34" wide drawer if I were putting heavy tools in it - making it 10" deep and packing it full of wrenches, for instance. But you won't be doing either of those, probably, so I think it should be able to handle the strain.
One thing you might do is imagine yourself working at the station and ask whether you would have to open a drawer while you're in the midst of sharpening; and, if so, whether splitting the drawer into two or more would facilitate your work.
Guillaume Dery
I divvy it up.
1 drawer for stones, slips etc.
1 drawer for files and misc measuring junk
1 etc. drawer (oil, lapping coumponds, loose grit, abrasive sheets)
it's been my experience that for things like this, I never needed a drawer that was more than 12"
Wider actually promoted lack of organization and things bumping into each other.
Actually, a 4th drawer would be beneficial. I think I smell a new base coming up for me when the workshop is done.
1 bank of 4 drawers and one door with 2 shelves to house the grinder and stone pond when not in use...
Curt Putnam
There is also a conversation going on Woodnet about wide drawers. The consensus appears to be that over 30" wide creates problems with wracking - not the weight. Since you have the option and the wider drawer is iffy it would seem the better part of valor to go narrow.
Wide drawers, per se, are fine .. but then their depth needs to be proportional to their width. Significantly wider-than-deeper has a tendency to rack in my experience. Of course, if the drawers are run on metal runners this may be a non-issue.
Per the wisdom of the group....
roger lance
the sharpening station will have at least six drawers instead of three large drawers.
