Re: Next project....a sharpening station
Guillaume Dery
Hey Roger, I jsut checked it out. for me, 36" is bang on the money for my height (just shy of 6') and my body mechanics when sharpening. You may want to adjust accordingly depending on your specs.
As far as formica goes... yuck! I think you are over worrying about the effects of water. You aren't exactly sloshing it around even when using waterstones. A tray or waterproof liner will serve you fine.
As far as design, quite a few things can be cribbed from Tom Fidgen (unplugged workshop). His sharpening bench meets quite a few requirements and would be darn near ideal for a lot of people. It's worth looking at for inspiration if nothing else.
Drawers are goodness. I am a fan of fit srawers sized to accomodate all your parapharnelia.
Next question (which influences your design) is what type of sharpening you will be doing. I will again refer to Tom because I like his philosophy of a station for all sharpening activities. In my case that would mean all edge tools in addition to saws and accomodate the power side of things (AKA the grinder).
So I have a granite reference plate set into mine (flat to within a thou) sort of in the middle, on the right hand side, I have an insert cutout which accomodates the grinder (premounted to a plate which fits the insert cutout) or my waterstone tray (keeping the top mostly dry). The waterstone tray is fairly permanent and the grinder comes out from behind it's door only when needed (then you swap the 2 out).
Left hand side has the saw vise mounted in the front and a metalworking vise on the edge.
just my 2 cents, your actual mileage may vary.
guillaume
