New WoodChat!
Wooden Jointer
Wooden Jointer
Michael Donaldson
Wooden Jointer
Michael Donaldson
I recently acquired a 22" wood bodied jointer. I sharpened the iron, squared up the sole and it works pretty well.
But I have a question about the throat. The throat is currently about 3/8". This seems way too big.
Do I need to close the throat, if so, do I just glue a piece of rock maple to the sole and re-cut the throat? How about grain orientation? in short.....I have no idea what I am doing. I love the the way the plane looks and really don't want to alter that too much.
In unrelated news, I also recently acquired a Stanley #71, type 1 router plane.
Re: Wooden Jointer
Re: Wooden Jointer
TomD
3 thoughts on the mouth:
1) Does it look like it was jackassed around with by someone who didn't know what they were doing? Or used by a pro to earn a living for a lifetime?
2) Based on the pitch, performance, does it seem like it was designed for what you do. For instance you only work ebony, but this was clearly set up to joint barn boards.
3) How is it working for you? If it works great, the wider the mouth the better. A wide mouth is better when a plane otherwise does what you want.
PS Look and see if the mouth, and plane sole are flat, that can also affect the quality of cut.
Re: Wooden Jointer
Michael Donaldson
Re: Wooden Jointer
Michael Donaldson
It looks (to my novice eyes) like it was used by a pro, and it is pretty precise. I mostly work with domestic woods (maple is my favorite). So far it has been working well, so maybe it would be best to just leave it. Thanks for the input.
Re: Wooden Jointer
If you do find...
...that the open mouth is problematic, you can let in a patch in front of the mouth, extending back into the mouth a bit to close it down, then filing the patch to the degree of "open" that you want. Your new router plane (nice looking tool) can be used to smooth the floor of the mortise you would cut into which to glue the patch. So, you see, it may not be unrelated news at all.
You'd know it's too open if you consistently get too much tearout when planing. The sole of the plane in front of the mouth serves to hold the wood down and assist in breaking the chip so that you don't get runout into the grain, which is what causes tearout.
But, I agree: use it first. People will sometimes spend lots of extra time fussing around with a tool because someone told them you're supposed to.
