Hand finishing drawer fronts
roger lance
On a prior thread, we talked about the possibilities of finishing drawer fronts prior to assembly of the drawers including the sides/pins....being convinced that for me it is prudent to finish parts of projects prior to assembly, I had to give it a try....
This is a photo of the drawer with blue tape to protect the vital glue surface in dovetail....and a photo with the tape removed....a little touch up required....
and the drawers in the case with dovetails showing....
and the piece ready to go into service....
thanks for looking.
....sitting in my basement waiting for me to take it on....lordy....if ever there was a piece that needed to be finished THEN glued....its this....water based dye loves to run....and although I'm able to command language that makes just about any combat veteran blush, that dye is gonna run on me....but I'm taking it on this winter and planning to use spray shellac when the weather turns....now that I've put it on the net, I can procrastinate on this no more....this is the foot board....the head board is under the wrap.
