New WoodChat!
A fun winter project....
roger lance
and I did use hand tools for shaping and flattening....but I made this cradle before I got a digital so no photos of the assembly which is a shame because there were clamps and wedges everywhere to bring this together....this project was on the list after watching Norm Abram (I know - power tool guy) make one....had to try the finger joints on double splayed sides and get away from the QSWO and use some cherry....by the way, women like this kind of thing. :)
thanks for looking.
Re: A fun winter project....
Purdy!
Alex Grigoriev
I'm afraid the air will get stale in this cradle, especially in the warm days. This may affect the infant development.
Gosh Alex, I hope thats not what happened to you
Real nice craftsmahship, Roger.
Beautifully executed
Re: A fun winter project....  Question OT
Joe in a Cleveland suburb
Very nice Roger.
Question... I've noticed in your previous posts/pictures the peg board in the background. How are you attaching the wood pieces, holding your tools, to the peg board?
Thanks.
roger lance
Joe....I built a plywood frame of scrapes thick enough so that I could mount two electrical boxes on the frame and be flush with the pegboard....there are three pieces of pegboard that make up the back.....and I placed a wood backing piece behind each tool location and screwed the tool holder into that backer board and then mounted the pegboard to the frame. In some locations, I was able to screw a tool holder into the frame.
I get it, thanks for the reply.
question
Bill Tindall
How is bottom attached?
Love the graceful rockers. Is there an especially nice doll to go in it? I haven't screwd up my courage to try slating dovetails or box joinery.
Re: question
roger lance
Bill....the surprising thing is that you will not have to do anything special to make these finger joints....I just cut them on a table saw with a finger joint jig....give it a try with a couple of boards with ends cut at 5 degrees.... :) ....simple....as was attaching the bottom....just screws in elongated holes.....the rockers are attached with sliding dovetails and a single screw in the center of the rocker from inside the cradle....
Pam Niedermayer
That's a really beautiful cradle, Roger, very nicely built.
Pam
Peeking at your bottom raised another question
Bill Tindall
there seems to be a brass plate under there. I presume is is a label of some sort. Is there a source of such things that don't cost a lot?
Re: Peeking at your bottom raised another question
roger lance
Bill....thats a maker's mark so future owners of the cradle will know who to blame....I get them thru Woodcraft....they have a man who inscribes the plate....look under name plates or try #145877....there is a variety of choices.
Archie
I need plans, sir!!! My wife and I found out that we will become grandparents this summer; so, I've got to get busy. That looks great.
roger lance
Archie....thanks for the compliment....but I don't have plans....when I make something, I just make some sketches to work out the joinery and figure out sizes etc....in this case, I'll give you some generalities and let you go from there....that cradle was made for a baby of up to 6 - 8 months so size it to what babies are in length and width at that age (ladies told me 30" plus)....the sides are all set at 5 degrees....I did the finger joints on a table saw with a 1/2" finger joint jig....make the sides wider than you will need in the final cradle (this will allow you some adjustment in fitting and then cutting/trimming to final dimension)....the sides are 3/4"....the base and rockers are 1 1/4" thick....I used a sliding dovetail to attach the rockers....the curve of the rockers and sides are set on a 48" radius....the cradle was inspired by one made by Norm Abram of The New Yankee Workshop and they sell both plans and video of their cradle....remember to elongate the screw holes to allow the base to expand/contract....a mattress can be made of readily available foam type material products (if you can find a commercially made mattress, you could size a cradle off that)....congratulations on becoming grandparents....hope this helps.
