Re: Need your opinions
TomD
Best method is one piece of 1/2 rod that is epoxied into the end of the beam, goes through the leg/motise/hole strucure, and is captured by a nut.
The way you do this is you get a 3/4 speedbore bit and drill about 4 inches into where you want the 1/2 rod. More is better 4 inches is enough. you make a jig on your drill press that has a 13 mm hole through it, or any hole somewhat larger 1/2" You screw this centered on the end of the stretcher. Remove the jig and put the rod you will mount in the end of the beam into the jig using enough tape and wax so that you can hold it there, but get the jig off later.
Pour enough west epoxy in the hole to fill when the bolt is inserted, about 1/2 full. You can spread any slight overflow over the endgrain where it will do no harm. Insert the bolt and screw the jig in place. The jig needs to have tape and wax on it's contact surface.
The end result is a bolt that grows out of the end of your beam. It is a lot faster to do than talk about. It is self-centering without any real skill to get a perfect result. If you had a choice between buying a bolt with a nut on the end, or a bolt with a bunch of loose expensive parts that were hard to line up, weak, and left a big hole in the side of your project, which would you choose? Not only is it stronger, better looking and easier to make up, but the real pay-off comes every time you actually assemble a base, it is a pleasure without a lot of fishing for parts.
Another few advantages to this method are that you can do it in the middle of a piece so large there is no place to get a nut in. I did it one the breadboard for my bench which was pretty massive to have done a captured nut set-up; it can also be done on discontinuous or squiggly pieces of wood since the parts do not need to be all that accurately cut, which I suppose is also true with the alternatives, but it is easy in this case. And it reduces moisture uptake, output of the pieces rather than making it worse.
The only downside is that it requires a place to upend your beam that is tall enough for the beam. When I did this with my workbench, I had to do it in a stairwell, but most stretchers are easy.
This is a picture of a 165 foot (diameter) wooden windmill blade that the Gougeons made for NASA and GE. These were mounted with 24 small epoxy bonded bolts at the root. The loads are massive, but the method works great.
http://blog.mlive.com/tricities/2008/04/large_turbine%20blade.jpg
And of course there is a youtube video:
http://www.youtube.com/watch?v=qHtf4zu5Xgo
The section "advanced fastener bonding" is closest to the mark, however we do not need the added cost of buying the white filler, and the method I described does not require you to drill an accurate hole to get an accurate result. Or I suppose it requires an accurate hole in a scrap of wood, just not in the potentially hard to maneuver beam itself.
This method does require some reasonably competent epoxy, 5 minute will probably not work or be easy to handle in this use. One needs WEST, MAS, System 3, etc... Most of these companies have sample size packs distributed at marinas, and boat stores, etc...
