Re: I wonder how these would work?
Hi Bill
I helped evaluate these films, working through a wad of different grits to narrow down the micron progression, and trying to get a fix on their longevity.
Keep in mind that these should not be considered a replacement of oil/waterstones in a permanent set up, but are ideal for working with PM steels or as part of a travelling kit.
That said, the films are amazing in their ability to hone steel, and their longevity. I have some that have been through several hundred cycles (per piece). Just be careful that you do not inadvertantly slice the film (with a rough edge). I use a little camilla oil for a lubricant. This works very well.
I pushed for the current sizing. Firstly, it is available in this sizing from the manufacturer I believe, which makes it cheaper I imagine. Secondly, I had the idea that one could (as I have) stuck all meshes on one 12" x 6" substratum (glass or whatever), which makes it convenient to store and use. A 6"x3" mesh is large enough for either freehanding or a guide (note: these meshes act like diamond plates - there is no cross contamination). The mesh requires very little "movement" to do its job. I did not experience an issue with dubbing. The mesh is unlike sandpaper - it is very flat and on a hard backing. Be sure that you clean the substratum well - dust below will create a bump, which will end up being sliced.
The meshes chosen (15/3/.5/.1u) allow for the least extra wear on each successive mesh ... in other words, the most efficient use of each mesh. You could forgo the 0.1u if you wish, but I must say that the addition of this takes the sharpening level to something well beyond "scary" ... frightening sharp.
In summary, these meshes are a must-try. Prepare to be amazed. You may not stop smiling!
