New WoodChat!
Water Stones
Water Stones
Water Stones
roger lance
First of all....Merry Christmas to all....especially to those with whom I frequently disagree....now to carry on with the discussion below, I will be getting that Veritas Mk II sharpening jig and be taking advantage of LV's free shipping period....but I also need to be getting some sharpening stones....mostly for A2 plane blades and chisels....so I come to you for recommendations....been thinking about the Shapton Pro Series (1K, 5K, 8K) and the DMT Dia Flat Lapping Plate (10"x4") to maintain the stones....but there are so many other choices including King, Norton, Bester/Imanishi & Sigma....so what say you ??....I hope all is well with you and yours....Merry Christmas.
Re: Water Stones
Re: Water Stones
Schtoo
All the stones you've mentioned will work with A2 just fine.
You don't need the DMT dia-flat to keep any of them flat, nor do you need the Shapton diamond plate to keep them flat either. A much less expensive alternative will work just fine, but do make sure the alternative has some reputation to speak of, and that the reputation is a good one.
I wish I could say more, but I do sell stones, and anything more I mention might be construed as pushing you one way or the other.
Stu.
Re: Water Stones
Re: Water Stones
roger lance
Stu....would a granite plate and some 220 PSA work well at keeping the stone flat ??....I have both....please feel free to e-mail me and lets talk....this is at my invitation....thank you.
Re: Water Stones
Re: Water Stones
TomD
The first thing to do is to learn to sharpen other than in the dead center of the stones. This is something the jigs tend to encourage. For just general hacking around, I think a jib makes sense, but I try to limit the use to when I loose feel for the the edge, which tends to occur due to rounding. If you felt like doing that, you could sharpen over the whole surface of the stone, and get far longer stone life, and also better edges, since for some of the time you are sharpening in the hole and that will not make for the best edges.
My preferred method for flattening is to buy two coarse stones. Like 800s. Rub these together till they are flat, and then use one of these to flatten the next grit up and son on. I have 100-200 stones, jigs, machines, diamond plates in the shop. One can't try it all, but I find the traditional method of rubbing stones works as well as anything else, and after trying a lot of other methods I ended up back at the beginning.
I also feel the same way about my stones. I have yet to see anything that works a huge increment better than King stones. The King 8000 will cause hair to pop, and I don't think most people are using anything much better than that. The curve of going beyond the basics means hours of rubbing out finer grits and just doesn't seem to be worth it. Every so often a new stone comes out, and I have quite a few of them, but mostly it is hype. There is a big difference between something that is different; something that is better; and something that makes a difference. It is rare than any of this stuff gets to making a difference, or even being better. Most of it is just a change.
Re: Water Stones
A question for water stone enthusiasts
Bill Tindall
If one is going to buy a fixed diamond plate why use it to grind a water stone instead of the tool to be sharpened? Form the perspective of someone that has no experience with water stones and lots of experience with diamonds it makes no sense to own a diamond "stone" and not use it to grind tools as an alternative to the equivalent grit size water stone.
Re: Water Stones
Wondering the same thing Bill.
Bob Hackett
And I own both water stones and a pretty good array of oil stones too.
Re: Water Stones
Re: Water Stones
Brian Greene
I have to wade in here. First off, I sell waterstones at Lee Valley. Moreover I sharpen the tools for our seminar program at the Ottawa store and I have been involved in testing stones. I sharpen more than most people and I have developed a system that allows me to be very fast and very good. Having declared my conflicts of interest, what follows are my personal opinions. Afterall, my boss lurks here too!!
Let's get lapping out of the way.
I use a 100 or 120 grit drywall screen on either plate glass (at work) or granite (at home). I use it for the coarse stone and then do each stone systematically off the preceeding: 4000 on 1000 and 8000 on 4000. Much cheaper than a diamond stone unless you have another use for the diamond stone such as grinding.
I disagree with some of the comments made. King stones don't cut A2 very well. The 4000 and the 8000 are also very close together. Deadly slow.
The Nortons work very well with A2 but they are very soft and wear rapidly requiring frequent and careful lapping.
I've been using Kings at home for 25 years and Nortons at work for five years. In both instances I have switched to Bester/Imanishi (700-2000-8000) and have been delighted with the results.
I tried Shaptons. Way too slow.
On the other side of this issue, the Bester/Imanishi 8000 stone at 1.2 microns is considerably finer than the Norton at 3.0 microns or the King at 2.0 microns. No, not all 8000 stones are created equal.
Merry Christmas all.
Re: Water Stones
Question
Bill Tindall
Well, first a comment....If I was going to buy water stones the recommendations of someone that does a lot of sharpening with experience with a lot of stones would be given a lot of weight. I wish we had persons from other companies that would weigh in more often with their experience on topics.
Now on to the question(keep in mind I have no water stone experience so a dumb question may follow)....If the fine stone is flattened by rubbing it on the coarse stone would not the grits from the coarse stone transfer to the finer stone and contaminate it with larger abrasive particles?
Next.....for free hand sharpening, why does the stone need to be flat? Even a stone with substantial wear will be flat for any practical purpose across the small length of the bevel. The bevel is registered to the stone surface, what ever the stone contour. Seems like the result would be the same whether the stone was flat or had an end to end arc.
Re: Water Stones
Re: Water Stones
joel moskowitz
Take a look at the current FWW magazine. They have a roundup of waterstones. You can argue some of the conclusions but the basic facts are reasonable. Also look at the last column on the quality of edge they produced. The article might not be the be all and end all but it is a coherent comparison of stones all by one person.
Re: Water Stones
Re: Water Stones
roger lance
Brian....it is very nice to have you in the discussion....virtually all the A2 plane blades I have are from LV, so your experience is most welcome....I have some older King stones as at one time King stones were about what was available in the American market....this probably precedes A2....the three stones you've recommended will make a simple sharpening system and I'm all for keeping it simple....I'm also for not buying what will prove to be unnecessary items which maybe includes an expensive diamond lapping plate....simple sand paper on a granite plate should work well ??? (comments please....I think the granite plate was from LV)....thanks for whatever you might add.
Re: Water Stones
Re: Water Stones
Pam Niedermayer
You may want to take a look at Stu's site. He not only has a set of Sigma Power stones (great for A2 and kin) for a package price, but most important he has a set of three videos demonstrating the system. Very informative.
Now I use pretty much white steel/O1/W2 tools, with the odd A2 exception (the miniature LV shoulder for example), and currently use an assortment of stones, mostly natural water stones. This has lead to kind of an ad hoc process which I expect to remedy in January with Stu's 1k-6k-13k plus Atoma diamond for flattening. Before this, I plan to put my Shaptons (2k and 5k) on ebay, really dislike the stiction, even though there are a couple of fairly easy solutions. I expect the SP's to be a lot faster (I also plan to buy the SP 400 and cf-700).
Pam, who has no skin in this game
Re: Water Stones
Re: Water Stones
Schtoo
Hi Roger,
Normally I would take this to email, mainly because I am intensely unwilling to show any bias that may make you sway your purchase. That's because yes, I do sell stones, namely Sigma Power (ceramic and Select II) Shapton (Pro, Glass and M5), Naniwa (Chosera and Superstones) Bester/Imanishi (many different stones, none labelled as 'Imanishi' so not the same as LV) King (Deluxe, Neo and soon Hyper) and soon, a few 'off brand' stones that have merits, but are a bit of a dead end if you're looking for a 'set' of stones. Good stuff, but mostly out there on their lonesome.
What Joel mentioned about the FWW article is true. The article does have flaws, but against all odds, the end results were surprisingly accurate with regard to the results that were required. Really very interesting how ugly it started looking, but how well it turned out.
To your original question.
A2 isn't much of an issue for most of the current crop of waterstones out there. The King Deluxe are struggling (and their design is 50 years old or so now), Superstones will struggle with a full bevel, but nearly everything else really doesn't care that the edge is A2. They're designed to cope with at least blue steel, which is probably no tougher than A2, but blue is usually significantly harder and poses more of a problem for a stone.
What you'll want to be considering now is which stones are going to get your blades sharp with the least fuss, trouble and the fastest. Cost can also be an issue for some, but I try to avoid much mention of that.
The points to consider are speed, dish resistance, ease of use (soaking, flattening, general care, etc.) and the resulting surface/edge on the blade.
In general terms, here's how they all stack up. (some of you may wish to save this. I don't write it very often, and never in public.)
Bester tend to be quite good. They stay flat and work fairly well. I find issue with my #1000 to be too hard, my #700 and #1200 to be too soft by comparison. I can manage that, but not everyone can. The higher grit stones are quite good, but my experience is very limited and I can't say they're 'that good' that I feel the need to pursue them for sale.
Chosera are excellent. They work VERY well, all the time. They do dish a little more than some, but they are very easy to use and work very quickly giving good surface finish/edge. Only quibbles are they're not that nice to flatten (sticky mud) and they can be somewhat fragile and problematic to soak at times. Small concerns, but still they exist.
Superstones can be summed up in one phrase. "They grind slowly, but exceedingly fine..." Grit for grit, it's nearly impossible to get a nicer finish off a stone than the SS gives. But, nearly every stone commercially available works faster. If you can stick to very narrow bevels, no problem. I find they tend to stay reasonably flat and work ok. Not my favourite stone, but if you work within their limits, they're nice and quite user friendly (no soaking, some feedback).
Shapton Pro are very good. The 1000 stays flatter than anything else out there. Needs no soaking, works fast and is easy to use. It's the star of the lineup IMHO. A lot of folks love the 1500 and 2000 as well, which I can agree with. The problem is that the other stones in the lineup are good, but not great. The #5000 can be a right PITA at times, needing a very gentle touch (unless you soak it, giving it some flexibility, literally), the #12000/15000 is nice enough (and nicer if soaked), but IMHO outclassed by a few stones in the outright edge it gives. Overall, not bad but not perfect by any stretch of the imagination.
Shapton Glass are odd. The low grit stones are really very good. But once you go beyond 1000, things start coming off the rails. They get progressively more recalcitrant to use, and while they can give very good results (better than the Pro ultimately), the envelope of operation is very small. If the Chosera are like an open roller door, the Shapton Pro are like a small, open window and the Glass are like a mail slit. They are compact however, tough and for travel, unbeatable. You just have to learn how to use them, and I, for one, am unwilling to bend to their idiosyncrasies because I have better options available to me. And no soak, but also very thin (and the stuff doesn't last!).
Sigma Power ceramic are very good. Second in dish resistance to the Shapton Pro at 1000 (places reversed at 5000-6000), easy to take care of and easy to use. The Chosera feel nicer, the Shapton Pro stay flatter, the Superstones give a better finish, etc, etc. At almost every point I can give you a stone that will do something better than the Sigma ceramic. The reason why I like and use these stones is that I can usually only pick a single stone that does something better, but in another area, the 'better' stone is something different. Rarely/never "the best" at anything, but usually second or third best at everything.
Sigma Power Select II, maximum overkill. In FWW testing they did 'poorly', but the testing was geared more toward the conventional stones, and did no favours for these things. Used correctly, the fastest stones available. Not so easy to use, since they do dish rather quickly and it's difficult to compare them to anything else because they're unlike anything else out there. If you want to consider these, google the heck out of them and communicate with folks who've got them and use them. Folks who have them usually fall in love with them, but they've also learned to 'tame them' somewhat as well.
You must also take into account what you'll be sharpening (in this case, A2) and how you'll be sharpening it. If sticking to microbevels and ruler-tricked backs, then all of the above are quite user friendly and will work very, very quickly. If more than a postage stamp worth of steel, that's where the stones mentioned as being 'not so user friendly' start causing some concern.
In short, there are so many variables and so many options out there it's becoming increasingly difficult to make a choice. A lot of the time the difference between one stone and another is only measurable under strict testing conditions. In the real world, it's nearly impossible to tell what stone did what if they're at all close in performance.
I think that the outright performance of a stone will become less of an issue in future, and more a case of "how nice is this stone to use?" It's already starting with a lot of people considering oilstones with their low maintenance, easy use and still good performance.
A lot of folks will not give up their waterstones though. But they will be looking more at 'how they work' more than the speed and outright edge, especially with more choice out there meaning you don't need to give up one desirable trait to gain another.
None of these stones should really be flattened with sandpaper. You can ignore that, and likely never have a problem. However, I've been specifically told by reps from Naniwa and Shapton to not use 'sandpaper' with the above stones, Sigma Power says "not a good idea". Bester, I don't know what they say. Softer stones like King Deluxe and Norton, it's an approved method so go right ahead.
I've been trying to work out why sandpaper isn't a good idea, since I was told that 'contamination' was the problem, and I don't think I understood correctly from what I was told (in Japanese of course) or those informing me may have been somewhat in the dark too and simply following the company line.
I think I've workout out why it's a problem, it's not what I originally thought was the problem, but the result is the same.
On softer stones, the sandpaper holds up well. Anything dislodged won't be stuck fast into the stone. On harder, denser stones, more particles can be dislodged from the paper, and with more of them rolling around, chances that some will embed in the stone is much higher. Because the paper is 'soft', it can more readily catch and lodge the particle into the stone. Loose grit on a hard surface tends to roll more easily, and particles don't lodge into the stone. Diamond plates hold their abrasive more solidly, so nothing other than stone material is present, and there's no harm.
I'll try and find out exactly what causes the concern, but really diamond plates are easier, loose grit is ultimately cheaper. I've never used sandpaper for stone flattening, and never will. The thing is, flattening should be done just before sharpening with the stone wetted down. Loose grit and diamond plates don't care about water, sandpaper (even W&D) does care about water and may give problems. I don't know what sanding screen will do, so I'll check that out too.
(But I know folks who'd be horrified about flattening a 10K stone with something so coarse!)
There's no reason you can't use steel on the diamond plate directly. The things to keep in mind are that you must let the diamonds do the work, which means little or no pressure. On a good stone, you can really lean into it which can make the work go faster. For flattening backs, diamond plates are good. Also know that working steel and flattening stones wear diamond plates differently, and combining the two tends to make the plate wear out a lot faster. It won't fall to pieces immediately, but the wear is pronounced significantly. You might also notice that the plate actually works faster with steel since the stone cleans the plate (which is partly why they wear faster). I've used diamond plates in both capacities, and will do so in the future but I tend to lean toward stones because A: I've got them and B: I prefer the feedback and ease of use a stone gives.
Also know that a diamond plate essentially gives you what it says on the box. If it says "10 micron/#1200 mesh/whatever!" that's what you get. The surface it leaves will be clean, but full of very sharp valleys, at least until the plate has significant wear on it (and at which point it's slowed right down). The next sharpening device should flatten out the peaks to the level of the valleys to the best of it's ability. A stone will leave more rounded valleys (but still rather sharply v-eed) and will also push metal around more than a diamond plate will. The simple version is that a diamond will sharpen your tools, but in a different way to a stone. There's a case for stones doing a better job, especially when taken beyond the #5000/2 micron level. Fewer sharp valleys, smoother edge. I've talked with some folks here about this, and the general consensus is that diamonds are ok in some cases, but none of them will use them for the final edge on anything but HSS and carbide. I tend to agree, and hopefully can do some testing to find out if there's any truth to this at all.
I don't know everything and I don't do as much sharpening as I really should. I don't have enough experience with every sharpening method available, but I also won't sell something for sharpening (at least) unless I've tested it thoroughly and decide it has something to offer that's worth the price demanded.
But, I hope the above helps. I hope it's not too biased in any direction, and the above are my genuine thoughts on the matter. Copy it down, but don't make it gospel, it's always subject to change.
(Especially when folks who make the stones send you samples to test. Apparently there's something new coming that might make some of the above null and void. But I don't know yet!)
Stu.
(I don't know why I wrote all that out. It's going to get attacked, manipulated and probably come back to haunt me. Merry Christmas...)
Re: Water Stones
Re: A question for water stone enthusiasts
Hi Bill
In my experience, diamond stones are not forever and, indeed, have a far more limited lifespan than many imagine. I have worn out a couple of coarse DMTs in recent years. Average life was around one year. No doubt Stu could tell us about better diamond stones than the DMT - but at the time I purchased these they were considered the d :O g's n :O ts.
When it comes to using diamond stones to flatten waterstones, they do have a significant advantage over other abrasive mediums. Firstly, what one is buying is a flat surface and, secondly, an abrasive that will not wear out much when used on a surface other than steel. And, thirdly, they are compact and easy to use and store. In other words, a ergonomic tool for flattening waterstones that will outlast the waterstones.
I use Shapton Pros on O1 and A2 (1000 - great stone; 5000 - poor relation, and needing to be changed; 12000 - pretty good). A few years ago I managed to pick up a brand new Shapton diamond stone at a sale for less than half price. It was still more than a DMT, but this was easier to justify at the time as I was hating the DMT I had (since it had been used on steel as well). It is still cutting as it did when I first got it, and it is so easy to use. I am not suggesting that everyone runs out and buys one - they are expensive - but a dedicated diamond stone makes a lot of sense to me. And it is not just waterstones - Larry will tell you that they are essential for preparing oilstones as well.
Re: Water Stones
Oops, forgot the link..  *LINK*
Stu's, Tools From Japan
Re: Water Stones
Thanks Shtoo
Bob Hackett
I would have to agree with your point that if you want optimum performance from just about anything you have to consider the entire picture. Matching the "steel to the stone" would be the most likely path to success and your post lays this out pretty plainly.
Trying to make one tool (to include sharpening tools) do everything has always resulted in less than what I had hoped for and many times in frustration. This is my excuse for retaining 3 drawers of sharpening gear rather than trying to pare it down to a single one. :D
Re: Water Stones
wilbur
I use waterstones for sharpening, although I haven't tried a huge number of different brands. I started with a Shapton Pro 1000/5000/8000 set. Since then, I've replaced the 5000 and 8000 grit stones with natural Japanese waterstones. I also use a 400 grit Atoma diamond plate that I use mainly for flattening my waterstones, and I have a Sigma Power 1000 grit, and I've played around a bit with diamond plates of finer grits, and a coarser waterstone.
On diamond stones vs. waterstones: it depends on what I am trying to do. Overall, the waterstones that I have cut faster than equivalent diamond plates. But if I am trying to remove a lot of metal, I'll use the diamond plate if my 1000 grit waterstone seems to be too slow. Overall, coarser waterstones dish more quickly, which the diamond plates don't do.
So to me, it's not an either/or between how I'm using a diamond plate or a waterstone. It depends on where you are in terms of sharpening your tool.
I completely agree with Stu's assessment of the Shapton Pro vs. the Sigma Power. I like the Shapton Pro 1000 a hair better than the Sigma Power 1000 mainly for the dish resistance, but if I had only one I wouldn't dump it for the other. My Shapton Pro 5000 and 8000 had some stiction issues, but as I used them more it seemed to go away.
One last reason to use waterstones instead of diamond plates: diamond plates give me that fingers-on-a-blackboard feeling that is annoying enough to me that I avoid using them whenever possible.
Re: Water Stones
Indeed, most informative  However....
Bill Tindall
The hardness of a tool is largely an independent variable from abrasion resistance. Hardness is measured by resistance to penetration and it is mainly determined by the bulk properties of the material. Abrasion resistance is mainly determined by the abrasion resistance of the minor amounts of the alloying carbides. As a result, the abrasion resistance (difficulty sharpening) of a selection of tools all hardened to Rc60, for example, can differ dramatically. Look for tungsten and vanadium in the composition. These elements form exceptionally abrasion resistant carbides. Their presence will make a tool wear well and sharpen with difficulty.
As I understand it "water stones" are a dispersion of hard abrasive particles in a soft matrix. Historically the abrasive was silica and the matrix clay. Silica is the softest of the abrasives normally used. Apparently it was fine for swords but it will not scratch the modern abrasion resistant steels effectively. Diamond is the other extreme. It will scratch anything, easily.
Frustrating, is the fact that the manufacturers of modern water stones don't reveal what the abrasive particle composition is, so it is impossible to judge the inherent merits of the stone's abrasive. Knowing whether the abrasive is aluminium oxide, ceramic aluminium oxide, silicon carbide, boron nitride, etc would enable the consumer to make some judgement as to the appropriateness of the stone for the metal at hand. Buyers of industrial grinding wheels demand this information; woodworkers don't. It is pointless knowing the tool is A2 and not knowing what abrasive particle is trying to scratch it, or not.
It is hardly like the composition could be kept a secret from a competitor, or even a curious user that had access to an X-ray diffraction instrument. Routine analysis would reveal the abrasive composition and crystal form. Regarding water stones as "pig in a poke" I stick with diamonds for I can then predict performance from the known composition.
Re: Water Stones
Re: Indeed, most informative  However....
Schtoo
Bill,
I typed out a rebuttal here, and deleted it. Decided it wasn't worth the aggravation.
Stu.
Re: Water Stones
Re: Water Stones
David Weaver
I have had everything you mentioned except the mid and coarse sigma power and the fine grit imanishi.
In the spirit of nothing really being new under the sun, stones just being a combination of variables, I would buy whatever you find a good price on and avoid glasstones because they are not a good deal in terms of abrasive content for the price.
Otherwise, I would get any of the hard ceramic stones, shapton, sigma, chosera, bester/imanishi, etc. and not worry too much once you get them.
I find of what I have, the choseras are probably the fastest for a given grit all around, the shaptons are very fast on carbon steel and pretty fast on A2. The SP 13k is a very fine grit stone, that's not quite as fast as the shapton pro 15k on carbon steel, but it's finer, and I can't tell how fine the chosera is, but like any other stone, if you don't keep the swarf off the surface, you get stray scratches from the swarf.
In terms of reality, though, if any of the above stones cause you any trouble sharpening, the problem isn't the stones.
I go back and forth with playing with stones (and it's just playing) but I always end up back to having two shaptons (a 1k pro and 15k pro) on the bench, and if those two stones can't handle what I'm doing because I am working too much metal surface, 20 seconds on a grinder solves the problem faster than working too much metal. I gravitate to those because the whole process minimizes how much time I actually spend sharpening, but still get an extremely fine edge.
The only exception is japanese tools, where you generally work the whole bevel, and I will use those two stones often, sometimes naturals instead for higher grit, and if I use those two shaptons, I add something in the middle - usually a 5k shapton or some 3k type of stone.
It's all play, though, there is no rational reason to not just have one decent set of hard ceramic stones and just use them and not screw around with all of the others. It's otherwise recreation.
Re: Water Stones
Furthermore......
roger lance
:D .....Stu....I will be studying your site and watching your videos....and then I'll send an e-mail to see what we can do....I want to keep it simple and straightforward and the particulars would be of no interest in this larger forum....so I will contact you soon....thank you for such a thorough response....very educational.....very helpful.
Re: Water Stones
Moses Yoder
Re: Water Stone Flattening
Moses Yoder
If you get ceramic or oil stones, you need a diamond stone to keeep them flat, or diamond paste on cast iron. Water stones are softer and you do not need the diamond plate. I flatten all my water stones on 150 grit drywall sanding screen on 1/2" plate glass; I am concerned if you used the 1000 grit stone to flatten the 4000 you would mix the grit of the stones, causing problems with honing. But if it works for him and you don't have any bias against it then it would probably work for you as well.
Re: Water Stones
TomD
I gather things may have improved, but my experience with DMT is that they wear out quickly when used to flatten other stones which is one reason I gave up on the practice. The problem was with the vitreous bond. Diamonds may be forever, but the stuff they are glued to the plates with is not, and is softer than stone schwarf. Every so often I gave it another try, but the end result was always the same. Super performance for a very limited time.
The Japanese make many diamond coated stones. Can someone point me in the direction of the stones they make for the purpose of flattening water stones. I have seen their loose SC plates, SC stones, and Ceramic stones.
Re: Water Stones
TomD
"The hardness of a tool is largely an independent variable from abrasion resistance. Hardness is measured by resistance to penetration and it is mainly determined by the bulk properties of the material."
Is this true? I would have though it a key variable that dept of penetration of a particle affected the rate of abrasion. And explains why stone have a very different effect on different blades.
Re: Water Stones
You're correct, it's a complicated science...
John in NM
Just one components of abrasion science that I recall off hand deal with the tendency of the material being abraded to micro fracture around the groove or scratch left by the abrasive and the direction of those fractures. Its not a well understood field of materials science, being largely results oriented until the last 20-30 years when the polishing of silicone wafers became a large scale industry.
So in a nutshell, penetration hardness tests don't really tell us much about the tenacity of the material, but given the ductility of even very hard steels, this may not be relevant to Bill's point. I doubt that the hardest steel fractures the way mineral and ceramic materials do. Last time I read about this stuff, there was one journal article.... one (David Barnett's probably read it :D I didn't). Fifteen years later there may be more.
However, it is of importance to understanding the abrasive itself. All of our useful abrasive materials either fracture or cleave in use, and likely accounts for the differences seen between various stones and various metals. Ever wonder how a diamond could be worn down by steel? Diamonds cleave. Silicone carbide is less useful for honing, and worthless for stone cutting, because though almost as hard as diamond it cleaves much more easily - so the effective grit size shrinks quickly under use.
Understanding and predicting stone vs steel type applications is going to be pretty futile without knowing about the abrasives used. This is about the one grinding or polishing application I can think of where ignorance of the nature of the abrasive is considered normal, and I agree, it is an odd state of affairs.
