New WoodChat!
The joys of hand stitching steel *LINK*
David Barnett
David Barnett
If I was paid by the piece to do this, I'd drop 14 stone my first year, and this démonstrateur isn't all that fast -- a little above average for a pro, I'd say (in his defense, the sarabande's not exactly up-tempo, either). Perhaps the factory noise would drown out my borborygmi.
On the other hand, it's not that difficult and kind of fun to make your own small rifflers and rasps for stone, ivory, and exotic woods, especially if you work from tool steel that's close to the finished size and shape. Annealing, then grinding or sanding a worn and rusted smallish half-round file or rasp makes for a quick start.
You need only to make a punch with a chisel end. I prefer two, however: a wider punch for the rounded side and a pointy one for the flat). When I first tried stitching, it was easier (for me) to get more consistent depth with the narrow punch (flats) and more consistent spacing with the wide (rounds).
Once you 'get it', though, it becomes easy to adapt to new blank sizes and profiles, punches and raised tooth sizes, and so on.
Larger tools require forging, straightening and more-sophisticated heat treating skills -- unless you'll only be occasionally shaping soft stone, plaster, hard waxes, and the like.
tip: At the beginning of each session, stitch a few lines on a practice piece before stitching your actual blank, and try to finish one side in a single sitting.
'nother tip: Homemade needle rasps work beautifully on boxwood, ebony, or ivory netsuke. You'll probably need magnification if your eyes are old like mine.
one more tip: and the most important one, match your hammer to your punch, blank and tooth size and stick with it. It can take years to get both consistent and fast enough to do this like a pro. I'm strictly bush league, far from a pro and chances are you're not intending to go pro, either, so take your time, have fun, practice, and if you don't own one already, buy an Auriou or two from Joel to see what it's really all about.
To get as wonderfully consistent as the guy in this video, at a moderate speed? Forgeddaboudit! Practice is one thing, talent is another altogether.
Hand-stitching rasps (link from a luthier's forum)
Re: The joys of hand stitching steel *LINK*
Mein Gott, David!
Is there a delicate shop skill that you DON'T have?
Thanks for the video. It's inspiring to hear from you that regular folks could actually do this.
I was struck by how much hand work goes into preparing the blank; and by the simple but clever fixture used to discourage warping when it's tempered.
Pam Niedermayer
David, welcome back, we've missed you greatly.
On the stitching, is the wider (in which direction? both directions?) chisel for the round parts a means of compensating for what I see as more space around each, what's it called?: point? head? protrusion? sharp point? Therefore, I see the area of round to be slightly more vulnerable.
I asked Noel Liogier about this, but no answer so far.
Pam
Any chance...
Bob Hackett
of a few pics of the business end of those chisels?
I too am very happy to see you posting again. :D
Re: Any chance...
Frank D. in Montreal
Hi Bob,
Hopefully David can fill us in or comment on these pics, but there's another video here; if you go to 5:28, you can see a closeup of the punch, which is pointy in the example:
http://www.youtube.com/watch?v=qPXp9184tA0
I've seen more rounded ones that look like the one here (this example is from a forum, made by an amateur):
One more pretty good pic here of a couple punches, with the hammer:
Thanks
IIRC you promised this about a year or two ago? Now here's a guy who keeps his promises! :D
Very inspiring.
Thank you Frank
Bob Hackett
Those pics were a big help.
Knew they had to have a sharp point at the point of contact to keep them from skating but wasn`t quite sure what the shape was that would form the raised portion of the tooth and still keep the tooth properly attached to the body of the rasp.
Interesting that a dog head hammer is used,just like a saw maker would use.
Robin Corell in Atascadero CA
Is there any tendancy for the blank to curl up from all the blows during the stitching?
It is amazing how a practiced hand can make something look so simple.
I've always wondered about this process
Bruce, a MN Galoot
Thanks for posting. I do have question for you, though. Is the steel left in the hardened state, or is it tempered in any way? The video doesn't show any tempering.
I don't have enough time in this mortal shell to learn all that I need to know. It's probably best if I just buy these someplace. :)
BTW, it's good to see you back!
Noel Liogier
Hello, I'm the guy on that video. Hope you don't mind me joining your community. Maybe I can answer some of your questions.
As regards the positioning of the blank for stitching, you need two things : a lead apron (for the precision of the work as this absorbs the vibration of the blows ; and it aslo prevents the teeth from being crushed when you stitch the other side) and to bend the blank and keep it under tension (on the video, you can see that the tip of the rasp, previously bent, is pressed down)
Liogier Website
