New WoodChat!
ADVERTISE HERE - FREE TRIAL
Workbench with storage?
Charles Jackson III
I been thinking about building this workbench for my small 10x12 shed/workshop The reason I like the workbench because of all the storage I can get in the cabinet below. I need to free up my wall space. I am wondering is it a good idea? I am a bleaded workshop so I use power and hand tools, well more power than hand. But I am trying to learn the hand tools as well.
Re: Workbench with storage?
TomD
There is a lot to be said for under bench storage. Drawers seem to be preferred, while cupboards are good for tailed tools. There are a number of designs out there suggested by shaker benches. The Shaker benches I have seen were often large enough for more than one to work at, and located in the middle of large shops. Many of us work in smaller shops where we are up against a wall, or perhaps 3 feet from one. Many hand tools store very well on walls, and the wall is the best option. During work, the base may get obstructed by workpieces or clamps. Also many of us have moved, and want a more easily broken down bench. Another preference some have is to have a tool box of traditional form for their bench tools, this allows one to have ready access, but not to be tied to a wall or bench.
Another solution can be to use the walls, but also the bench for longer term or awkward storage. My bench has trestles under it with long deep aprons, and these have a shelf between them that can hold a lot. I also have a shelf over the trestles. It still retains the look of the open base, but has a lot of storage, and I can easily grab larger planes.
Another version of that is the German tilting chest, that I must say intrigues me:
http://www.wood-shop.co.uk/shop/ECE_Underbench_Tool_Drawers
- Be sure that the overall weight will not move, and cause all kinds of rattling and tool joggling. Not normally a problem but the bench in the pic is on the small side.
- Benches should be 7-8 feet long if at all possible, and even if the full length may not always be accessible. Most benches need to be larger than the largest piece of wood that will go on them. With the furniture modules we have that can easily be 6 feet. Yes many people are very happy with their smaller benches, though I never was happy with my 5 footer. In the overall picture I would trade a lot of other fancy stuff for more size.
- You may well find that your commitment to hand tools gets larger as you go along. Particularly once you get the bench. Don't get me wrong I use a variety of tailed tools on my bench, but normally for as little as possible. I have dozens of small and stationary power tools, but I do not mix them as much as one might think, with my hand tools. There are all sorts of reasons from cleanup, to space, to the fact I get better results with the hand tools at times. As well as the reverse. Therefore I would go all out to serve the hand tools, the power tools will work well on a hand tool bench, while the reverse is not always true
roger lance
Charles....go back about 5 pages on this board to postings of 9/15/2011 and you will see a picture of the Shaker style bench I made years ago. If you decide to build this style of bench (which I still like very much), I have some suggestions: first, make sure that the face of the cabinet is 1/2" at least behind the front row of dog holes and make sure that the top edge on the top drawer is at least 3/8" below the bottom of your dog when that dog is fully pressed down in its dog hole; otherwise, when you pull out the drawer you will be hitting the dog and you will be tempted to say naughty things....second, go entirely with drawers....drop the door area as a couple of tools will fill that space and you will be looking for more storage....when I designed my bench it was a shot in the dark on drawer size as I did not have a large hand tool collection to guide me on sizing....you'll only really know what sizes you will need when you actually have the tools that will fill those drawers....still the progressively larger drawers are a good idea which I'm making use of now....third, install a tail vise as well as the shoulder vise....I use both almost equally.
In a small shop*, you want to use every cubic inch of storage. Consider how you'll use the space under the side overhangs. It's true that you need somewhere for the vise to run - can you build the bench so that there are holes in the structure to accommodate the vise and still have storage underneath? Or will it make more sense to have separate storage boxes/objects in that area?
Under-bench storage can be a pain - you have to anticipate what tools you'll need before you clamp that big piece of stock in the face vise for working on the edge, or else you'll be removing it to get to the tool you need. If you have the space, use the storage under the bench for things you need to have in the shop, but don't use as frequently; and have frequently-used-tools in another storage space, near the bench.
*I know whereof I speak: my shop's 12x12 (11x11 if you measure the floor space), and every stud bay stores SOMEthing; and there are saws hanging from the joists, a very inconvenient place to store them, but they had to go somewhere.
Bill Tindall
I like an open space under a bench because I often work at the bench while sitting on a stool and I need some place to put my feet. I would not find cabinets under a bench to be handy. I would much rather have the cabinet hanging on the wall behind the bench, or better yet, shelves behind the bench. I would find having to open a cabinet door to get at some needed tool an inconvenience.
But the bench does look nice.
Charles Jackson III
Thanks guys, I may have to build a hanging tool cabinet.
You are right on.
Re: Workbench with storage? *LINK*
Bruce, a MN Galoot
There is an article by Matthew Teague in a Tools and Shops edition of FWW a few years back that has a plethora of ideas of how to manage space in a very small shop. I hope this link will take you to the PDF of the article:
Matthew Teague on Small Garage Workshops.
TomD
I prefer racks. They protrude less into the shop, are much more accessible. Are in some ways easier to keep dust free. Look nice (or the tools do), are more easily configured, hold more. But then you don't have to choose you can probably have some of both. I do wonder the extent to which cabinets grew up out of the need to protect the tools from itchy fingers. Not something I worry about in my shop for the most part.
Charles Jackson III
This is my current hand tool area, but I would like to put a window in this area.
Yes to widows
Bill Tindall
It takes an amazing amount of fluorescent fixtures to equal the light of one window.
Most definitely
John in NM
After 5 years of a shop in a basement, I now have windows.... a vast improvement :D
