Bench Conversion
Todd Nebel
I mentioned a few months back that I was going to convert my bench from a power tool bench to a hand tool bench. It's almost there. I need to drill more bench dog holes and I'm thinking about adding a rack on the left side back to hold chisels.
I started by flattening the top. This was the first time I ever did this. I recently bought a No. 8, so with the No. 5 and No. 4 1/2, I had the tools. When I built the bench in 2000 I used a belt sander. It was remarkably pretty flat but not flat enough for planning on. My biggest struggle was the hickory wood and I never bothered to match the grain. So, much of the flattening was cross grain as you can tell by the chips on the floor.
Then I needed to reduce the height by seven inches. I took off the legs, cut them down and used the feet as cross members which are mortised and tenoned into the legs. Before I glued it together I drilled three holes in the right front leg for holdfasts. When I attached the top I made sure it was flush with the front legs.
Once the bench was back on its legs. Then I changed the wood on the front vise to a thicker and longer chop and added a couple dog holes. Next, I bought a second vise to use as a tail vise. I made the chop extra thick to support some of the board when the vise is extended. I added leather to the inside of both vises. Should have done this years ago. The last thing I did was add a shelf today so I have a place for the shooting board, other jigs and miter box. I've working at this a little here and there for the past couple months.
I also made a sawbench (need a second one). You can't see it in this photo, but there's just enough bug holes and tracks that I didn't want to use the walnut for furniture.
Next, is a Moxon double-screw vise. The lower bench is great for hand planning but murder on the back for sawing dovetails. I must admit the sawbench has seen more use as a stool than a sawbench.
Todd
