Another drawer question
Patrick Gibbons
Is a slip warranted for 3/8" sides?
Patrick Gibbons
A novice opinion
Bill Tindall
I have just started to use them so I am no expert, but it seems they aid two challenges. First they distribute wear over a larger surface, promoting drawer life. But, they also provide a groove for the drawer bottom without compromising a thin drawer side. And given the handy technique Ian, or someone, reported for installing them I could make a case that overall they don't add significant time to the drawer construction. Furthermore, I like the look they provide inside the drawer.
Re: Another drawer question
TomD
If the idea is at what size does it become necesarry, sorta hard to say since that is a big drawer in some cases and a small one in others. One thought is that when relating a single number to volumes the size of the part goes up to the cube. So mechanically you might double the reference number and increase the weight 8 fold. THe bearing would go up 4 fold. Of course you might not if the stuff going into the larger drawer were feathers.
Another thing to keep in mind is that wear relates to the actual part of the parts in contact, which however wide you make them, or even because you make them wide is likely to be small in the case of wood. Even machined surfaces often have poor engagement, and it takes very careful re-machining to get perfect bearing. So if you are really rubbing together rather small points, it would become all the more important to ask a question about how those parts play together, and what wood choices might be better. I personally wouldn't want to use UHMW plastic rubbing surfaces, but thinking of wood as to it's wear against wood is much the same kind of idea as the obvious one of making the contact surfaces out of plastic.
roger lance
you're channeling Professor Irwin Corey !!......right ????
Re: ???....
TomD
I think that is unlikely. Simple version is side thickness represent wide variety of potential drawer sizes, and area of contact is only one determinant of long term wear.
Bill, what technique are you talking about
Re: Bill, what technique are you talking about
Bill Tindall
See my 10/21 post on the main Forum page.
