New WoodChat!
Shaker Table Completed
Todd Nebel
It's done! Thanks for the help along the way. Happy to answer any questions if there are any.
Re: Shaker Table Completed
Second Photo
Todd Nebel
I went with three evenly sized boards for the top.
Third Photo
Todd Nebel
Close up on the leg beads and the drawer front. I turned the knobs.
That is beautiful Todd. Not just the choice of wood, but the execution.
Want to trade it for one in Jarrah? .... I thought not! :)
roger lance
Todd....I like it very much....you did very well....and I like that top....the symmetry of the three boards works so very well for me....there is no distraction of the eye by looking at disproportion in the boards....the eye takes in the reassurance of the balance/symmetry and goes to admiring that stunning figure....congratulations.
VERY nice
The Shakers had it right: 'tis a gift to be simple.
GolfSteve in Calgary
It's a spectacular beauty. Nice job on the top; matching figured maple like that is not easy. Great photography also.
I have to admit I don't like the visible dovetail on the rail under the drawer.
bob murphy
Beautifully done!
I agree. Given the difficulty of "matching" grain on tiger maple, where the cross-grain pattern is the dominant pattern, three boards the same size makes the most sense.
Re: Sweet!  What's next?
Todd Nebel
Hi Bill,
With the leftover wood, pre-mixed dye, and shellac; I think I will make a small cupboard to hang on the tall wall near this piece. I just need to find a design I want to build.
Todd
Thanks for all the kind words.
Re: Third Photo
Steve Kirincich
Beautiful! Can you comment on the finishing sequence? Thanks.
Steve
Gary
Nice work!
Re: Third Photo
Todd Nebel
Hi Steve,
The round part of the legs were sanded on the lathe to 600 grit. All other flat surfaces were planned only prior to finish.
It went something like this...
Wet the surface to raise the grain and used an old 320 grit piece of sand paper to knock off the fuzz.
Applied a 1/8th strength coat of water based dye (Honey Amber). Used a cotton cloth and let dry over night.
Applied a full strength coat of dye. Used a grey scothbrite pad and "kind of sanded" as I applied. Let dry over night.
Applied a Linseed Oil bath. Let dry a week.
Applied several coats of amber shellac (1 lb cut) and then many coats of clear shellac (1 lb cut). On the weekend I could apply 3 coats a day, during the week only a single coat after work. I lost track of how many coats in total. At first I used a grey scotchbrite pad to sand between coats of shellac, but as the shellac built up I used 500 grit sandpaper.
I ordered some Liberon Bison wax (Yew color) online. When that arrives I will add a couple coats of wax.
Hope that makes sense and helps.
Todd
