Hot hide glue mishap
Robin Corell in Atascadero CA
Yesterday I had a rather messy catastrophic failure of my glue pot. The set up I have been using for the last five or six years is a mini crock pot. The crock pot I have was free with the purchase of a regular size crock pot and it was recommended for warming cheese or been dip. One cup of dry glue will fill it to the brim when mixed with water; I usually mix 3/4 cup dry 192g glue.
The mini crock pot gets way too hot so I made up a 4 gang box with a receptacle on one side and a dimmer switch on the other, combined with a meat thermometer it is a set up that has served me well. The dimmer switches last for a bit over a year before they need to be replaced, which is more of an inconvenience than a financial consideration. It was always in the back of my mind to pick up a variac and last summer a good friend gave me one, so for the past couple of months I have been plugging my mini crock pot into a variac rather than my home made set up with a light dimmer switch. The difference between the two is that with the dimmer switch the glue would come up to temp and then over a few hours it would slowly continue to rise and with the variac it will hold at whatever temp I set it to with no creep.
When I know I will not be using glue for a week or two I put the whole crock pot in the freezer and I have never had a problem until yesterday when the bottom of the crock pot blew out. In the past when I pull the glue out of the freezer I usually forget that it has been frozen and I need it hot ASAP so I crank the dimmer switch till it is up to temp and then back it off to its holding temp setting, but I am not sure if I have always heated my frozen crock pot by cranking the dimmer. Yesterday I pulled the crock pot out of the freezer and plugged it into the variac and set it at the holding temp setting because I had a doctor’s appointment and would not need the glue till after noon, I had meant to turn the pot of while I was gone but drove off with it plugged in, which should not have been a problem.
During the time I was home and monitoring the glue pot it was not defrosting like normal. Usually the outside edges would melt a bit and slowly the lump in the middle would disappear. I have only used the variac with a frozen glue pot one other time and that time I was in a rush to heat up the glue so I cranked it to high and then backed it down to a holding temp. I am now wondering if the variac is so controlled that it melted a small amount in the very bottom but none around the edges and as the melted glue expanded the frozen glue at the top caused a buildup in pressure that blew the bottom off the pot.
Of course it could be that the repeated freeze thaw cycles of the crock pot caused small stress cracks and yesterday it just reached a critical mass so to speak.
A third possibility is that a couple years ago I cooked the pot dry and the drying glue pulled a couple of chips off the sides of the crock pot and this caused damage that eventually caused a failure. I suppose you could even argue that it was a combination of all three scenarios.
I do have a back up mini crock pot so I will be able to melt up some glue for this afternoon. I really do not want to repeat the mess I created yesterday, luckily I discovered it in time otherwise my Gerstner box would be firmly attached to my bench. I am sure I could limit my problem by not freezing the mini crock pot but it has saved me a lot of wasted glue over the years and has up till yesterday worked very well for me. I would like to hear other opinions on what might have happened and how best to avoid a repeat.
Sorry for the long post without pics but when I saw the mess I sort of panicked and by the time I thought about taking a pic I was elbow deep in gelled glue mess.
Robin
