New WoodChat!
I dyed last night
I dyed last night
I dyed last night
Todd Nebel
Well, I went for it and so far I'm really pleased. I followed a receipt from Jeff Hewitt to "Pop the curl in curly maple". It involves a Honey Amber dye dissolved in water and applied first at 1/8 of the strength and then at full strength. I dyed the piece last night and let it dry over night. This morning I flooded the surface with boiled linseed oil until the wood couldn't absorb anymore, then wiped up the excess. I was so pleased with the result so far I had to take a picture and post it. Next steps are to let dry over night and apply another coat of oil and while wet sand with 400. Then dry two days and apply amber shellac. This is a departure for me with maple; I've always used a wipe on high gloss poly.
Re: I dyed last night
John Pappas
You should be pleased with the way your efforts turned out. I like your choice of color. Also, I might be inclined to allow a bit more time between the BLO and the shellac....just to be sure.
wowy zowy!
I agree on more oil drying time.
Bill Tindall
The rate at which oil dries is so very sensitive to temperature. Personally, I am now cautious when drying linseed oil is involved. I had the shellac literally fall off a walnut piece that was oiled before shellacing. After that unfortunate experience I wait a week. Under favorable conditions 2 days could be adequate while under cooler or damper conditions it might not be.
Re: I agree on more oil drying time.
Todd Nebel
Good advice. I'm actually busy this week so it can wait until this weekend.
TomD
As you doubtless know with your technical bent, you can control drying time with driers. Either as separate entities or by mixing short varnishes that contain driers, while maintaining the mostly oil character of the mix.
varnish vs oil
Bill Tindall
I have wondered whether a coat of thin, more predictable drying, alkyd varnish would yield the same effect as the oil bath. I don't understand how the oil works to add depth so I can't predict whether the varnish would be equivalent. Where is Fleexner when we need him?
I have quit mixing pigments into oil to make stain . I mix them into alkyd varnish instead to get predictable drying. I had a disaster with uncured oil once.
On the topic of adding stuff to already formulated finishes I don't do it, other than solvent. Finishes and finish chemistry is "black art" and I know just enough to know that I can't predict a result. For example, the catalyst to promote drying can promote degradation of the finish in light. I don't know how much is too much to use.
Re: varnish vs oil
Todd Nebel
I don't know much about the chemistry behind finishes. Actually the process I'm following from Hewitt has a wet oil sanding between the oil bath and shellac. I don't know why this is needed because the wood is smooth and the very light sanding cuts through the dye if not very careful. Hopefully it's not needed because before I got to far and ruined the dye job I stopped. Not sure if it's needed for the shellac.
Re: varnish vs oil
Warren in Lancaster, PA
Oil followed by shellac is a traditional finish. No sanding is needed (or desirable) if you have a nice smooth planed surface.
procedure from Alf Sharp
Bill Tindall
For those that don't know Alf was the SAPFM Cartousch winner a couple of years ago which puts him at the best of the best of people making Period Furniture. I find advice from these people to be the best. Additionally Alf is a wonderful person willing to share his experience.
Alf's recommendation for a finish like you are doing was to dye, very light sanding to remove fuzz, flood with oil and after all had been absorbed that was going to be remove excess. Wait at least 3 days and then finish with top coats of shellac.
Thanks Warren and Bill
Todd Nebel
That's what I was hoping to hear. When I applied the dye it was after I had already wet the wood to raise the grain and then sanded. The first coating of dye was at 1/8 the strength and using a piece of a soft cotton tee shirt. The second was at full strength using a gray scothbrite pad. The scothbrite pad knocked down any new or remaining raised grain. It was smooth when I added the oil. As I mentioned earlier Jeff Hewitt's next step after the oil bath was to apply a light coat of oil and wet sand with 400 grit paper. He went on to say if not careful and you remove the dye, add dye to alcohol and touch up the spots. Then when dry apply a 1 lb. cut of shellac until you reach the desired result. I was left wondering why I would need to sand one last time before the shellac. It's risky and the wood is already smooth. So, thanks for the responses. I will start laying on the shellac tomorrow evening.
A name correction if I may....
roger lance
Todd.... that's Jeff Jewitt of Homestead Finishing Products which features TransTint dyes....he's worth knowing about....use his finish schedules for A&C/Mission furniture as well.
Re: A name correction if I may....
Todd Nebel
Thanks Roger. I was reading a back issue of FWW just a few minutes ago and realized my spelling mistake... and here's your post. I also have his book so that makes me feel foolish.
roger lance
well the H & J are right next to each other on the keyboard...it was just a simple typo.
