New WoodChat!
A question on planes
roger lance
it takes me awhile to adjust a plane to take a nice thin shaving....once you have a plane set to take that shaving, do you leave it set with the blade extended for the next time you will use it??....or do you retract the blade and put the plane back into a stored state to be adjusted whenever you do need to use it again?? I'm sort of influenced here by what you would do with power tools like a bandsaw....ie take the pressure off the blade and loosen things up for the next time. What do you do with hand tools??
Re: A question on planes
I leave mine as is
craigd
craigd
I always leave my planes ready to use; my plane "trees" have little shelves so I can just grab a plane and use it. And put it away, which helps keep them out of the battle zone. The shelves are getting chewed up (planed) but they are wood. The only planes I tend to retract the irons on are the scrubs (I think I do this because the iron hanging out tends to catch and make placing it on the shelf finicky).
I can answer the band saw question
Bill Tindall
I have never seen a commercial shop loosen a blade when not in use.....nor have I.
Planes & Bandsaws
Steve Elliott
For my work in commercial shops I needed my planes to be ready to go without any fiddling around. My smoothing planes were sharpened and adjusted at home for a .001” shaving and then sometimes adjusted as needed at work. My wooden rabbet planes were set for a slightly thicker shaving and seldom adjusted at work.
Home hobbyists don’t have an owner or a foreman to answer to. When I was a foreman I can’t say I was pleased to see someone honing a blade at work, but the better they were with planes the less I minded it.
As for bandsaws, we had one for resawing with a very wide blade that took enormous tension. It had to be de-tensioned between uses to avoid damage to the wheels. The only problem was if someone forgot to re-tension it and started it up.
Re: Plane trick & bandsaw blades
North of the Border
I treat them differently:
a) I always detension my bandsaw blade to avoid unnecessary stress on the blade, wheels, and tires.
b) I leave the desired setting as is unless I know I am going to change it in my next shop session.
c) Before I lay down my plane, I put two fridge magnets on the bottom of the plane to keep the blade edge from hitting any hard surface, or in case the edge may scratch a surface by accident.
I should comment, first, that I'm a metal plane user - not sure if I'd change my practices with wood-bodied planes.
My most commonly used planes live on a shelf with a little batten placed where it will be under the toe of the plane, lifting the mouth off the shelf; and I leave them set in operating position. I do this mainly for speed - I can pull the plane out and use it right away. I set my No. 60-1/2 block plane on its side in the drawer where it lives, with the iron in operating position, because I haven't had time to organize small plane storage in a way that supports the batten approach.
When reorganizing plane storage reaches the top of a very long list, I plan to apply the batten technique to storage for all the planes (do NOT ask me what that total number is; the answer would just be too embarrassing).
I don't think having the iron in operating position applies any additional pressure to the plane's mechanisms, so the major possible harm would come from dinging the carefully sharpened iron.
I do, on the other hand, de-tension my bandsaw blade between uses (I installed one of those Carter lever devices), because there seems to be some evidence continuous tension affects wheel roundness and bearing life, and, with the Carter device, de-tensioning and re-tensioning take seconds - and the presence of the little red knob right down at table level makes it pretty obvious that the blade's not in tension.
TomD
There is tension in a plane system since there is either a cam, screw or wedge, etc... applying blade retention pressure. I have never heard anyone suggest this is a problem, and as there can be dozens or a hundred or more planes in a shop all adjusted to go at a moments notice, it is a good thing that this does not present a problem. I have been at woodworking now for over 30 years, with some wooden planes I made back in the 70s still hanging around. They show no sign of damage, or age, other than use. This is quite different from antique planes that sometimes do look as though they had split off the wedge. Whatever the cause of that, it is not something that happens in one career apparently.
With a bandsaw, that is a specific situation. There are many parts of the bandsaw that are under pressure but are not let down. These would include the guides, or any screw really, motor mount or belt tension. You could probably find dozens that are bottomed out in a similar way to the way a plane is hardened down. The blade is the only one of these that receives special consideration. I have never really had a problem as a result of it, on a serious saw, but one hears stories. The blade itself is sprung, pretty hard to see that reaching a yield. The frame is under tremendous pressure, and then there are the tires. I have made the odd mistake and come back after several months absence, and never seen a problem. Just this summer I left the leather drive belt on my south bend lathe under tension, a weak link if ever there was one, and no difference in performance on my return. But I still wish I hadn't.
