Have a question? Ask Woody!
Whatsit identification
Moses Yoder
Moses Yoder
I am posting this piece for a co-worker who also has a number of old tools. This one has both of us stumped. In this end view you can see a clamp that I assume would go at the top of the piece, for holding something like maybe watches or jewelry.
Next we have a side view.
And last is what I assume would be an upside down view. The pin at the top in this picture I think would be inserted in a hole in the work bench, with the clamp on top of the piece holding the work. Any thoughts or information would be appreciated.
Re: Whatsit identification
Stephen Shepherd
Stephen Shepherd
Moses,
It is a jeweler's or watchmaker's chuck for a lathe or rose engine. The shaft fits in a collet chuck in a bow lathe or rose engine.
Stephen
steve mackay
Sure. Hand vise. Neat one too ! Never thought of the pin to install it on the bench though. Clever !
Re: Whatsit identification *LINK*
Peter McBride
This is part of an engravers vice, the half ball, and leather or wooden ring is missing from the bottom. A very nice thing indeed!
The brass bearing plate is there. I have seen sets in engravers workshops with a selection of different tops for various work.
Using mine, picture below, I will sometimes fix the work to a wooden block with shellac, and then clamp that in the vice.
Engraving requires the work to be rotated as you work the graver, it makes the creation of scrolls and curves much easier.
I also use mine to hold work for setting diamond and other gems.
I can't see it being any use in a lathe, it wouldn't need the length provided for a hand grip, moving the work that far away from the chuck or collet for no good reason would only make your turning more difficult, and that would seem crazy to me. Everything between the brass jaws and the steel shaft would be a hindrance, not a help.
Regards,
Peter
In Melbourne, Australia
http://www.petermcbride.com/jewellery_tools/
Robin Corell in Atascadero CA
It does have a holtzapffel kind of a look to it. I doubt it is actually a Holtzapffel accesory but I can see where it could definately be used on a rose engine.
A pin vise doesn't makes sence because the turned wood portion lacks any wear as well as an appropriate handle shape.
A gravers vise is also not totally convincing due to the missing ball and the almost extreme length between where the ball would be and the work.
A very good whatsit for sure, one of the nicest Iv'e seen in a while.
Robin
Stephen Shepherd
Stephen Shepherd
Robin, right about it not being an engravers clamp. If you look at the clamp it is a centering clamp to insure the work is centered for turning on a lathe. And the stem shows no method of attaching it to the weighted ball, but it is easy to clamp in a collet chuck in a watchmaker's or jeweler's lathe. Not substantial enough to take blows from an engravers hammer.
Probably used for engine polishing but also for gear shafts, small trunnions or tiny pintels or rivets, etc.
Stephen
TomD
Lathe wise it would seem off balance. The engraving tools shown are used with palm pressure, no hammers involved. I was thinking engraving, but I don't know.
Peter Mcbride
Stephen,
So, if you had a collet lathe, would you take out the collet the right size for the work...fit up that thing which is 10 times too big, has a chunk of wood as big as a hand and the most unsophisticated, unbalanced chuck ever contemplated, then fit up the work ready for turning......?
Here are some of the watch and clock tools I've collected. Look at the boxes of bow drill tools...they are tiny.
http://www.petermcbride.com/watchtools/
I'm afraid that suggesting this is used in a lathe for anything to do with watch, clock or jewellery making shows a fundamental lack of understanding of how that work is done, and how highly accurate and refined are the tools used. The scale is the thing. It's as big as a hand, and that is just 10 to 50 times too big for the work.
I've made jewellery for 35 years. As well as the tools above I've a significant collection of jewellery making tools that date back to the 1850s, and a pretty comprehensive working knowledge of how jewellery was made through history. I have 4 watchmakers lathes, and 2 more small lathes that could be used for jewellery, and all of them are too small for what you suggest.
I use a couple of tools of this type. and, I've seen wooden ones like it used by now retired and deceased engravers....please believe me....that is part of an engraving tool. It would never find it's way on to a lathe. The person who you suggest might use it (that would be me) would think it absurd. You must remember we are making a far more complicated object than that tool, and so we just make the right tool for the job, including a collet if it's needed.
Here is another picture of the engraving ball vices. The shaft isn't ever fixed, and I have no idea what you are talking about using a hammer to engrave jewellery.
Regards,
Peter
