New WoodChat!
Lance' Workbench
Lance' Workbench
Moses Yoder
Lance' Workbench
Moses Yoder
We are doing some experimenting with Roger Lance's pictures. This is his bench; I will let him answer any questions about it. :b It sure is a beauty.
I resized it using Microsoft Office Picture Manager and I think when I saved it the resolution changed considerably. The original picture is around 2.44 Megabytes and this one is modified to be around 85 Kilobytes to be under the 100 Kilobyte upload limit.
Re: Lance' Workbench
Curing the fuzzy
Bill Tindall
I have a friend that is a semi-professional photographer. He wrote down a simple route to better photos for posting. "step by step" is the only instruction that works for me.
With the photo on the screen I right click and open the photo in Infanview, a free photo processing program. Then I resize it to "500" something-or-anothers under the "image" menu. Then, again under the image menu I click "effects", "effects browser" and "unsharp mask" and by some miracle of how ever it works, fuzzy becomes crisp.
Another handy function is crop. Left click, hold and drag a box around the desired area. Then under "edit" click "crop selection".
Then one needs to save this image. "File", "save as" . enter where to (I use the desk top) and save. Check the size of the file and if too big then when saving use a lower number under the "quality" box.
Thank you so very much Moses !!
roger lance
I completed that bench about the time Badger Pond closed....and it has taken all this time to get my first picture on the net....thank you Moses!....sorry for the size of the file I sent you....but it worked!....I've wanted to show this bench for awhile...especially to Jim Shaver in Canada....Jim also finished his bench about the same time....and I was always struck by how similar our benches turned out in size and dimension....I also followed the Workbench Book by Scott Landis (which IMHO is one of the best written ww books out there)....the bench is a composite of three major influences....Michael Fortune on the left for the building around the Record shoulder vise, Frank Klausz on the right for the old fashioned tail vise that operates on wood runners, and the Shakers for inspiration for the middle....I'm responsible for a little embellishment. This bench has served me well....its great to work on and always holds the work (at least that I do). There is a file on WC for Jim's bench....look it up....its a great bench. Thanks again Moses....I'll send a couple of photos of the four drawer nightstand....only a couple....and I'll get some education at the Apple Store and stop being a burden. Thanks again.
Re: Thank you so very much Moses !!
Bruce, a MN Galoot
My own bench is about the same size, but more than half of the bottom is an open shelf that holds a lot of jigs, bench hooks, etc. Now that you've used your bench for a few years, do you still like having drawers underneath? Are there times that they get in the way?
What brand of wood went into it?
Yours is a real beauty, for sure!! Very nice job.
Pam Niedermayer
The easiest and cheapest way to resize a photo on the Mac is with Preview, available free with every Mac. Open the photo in Preview, go to the Tools menu and choose Adjust size. That's it.
Pam
Lovely bench!
David Weaver
That's a great looking bench, Roger, regardless of the finish date. :)
I love a nice bench with a tail vise.
roger lance
Bruce....thanks for the compliment....the bench is almost 100% hard maple....maple ply for the bottoms of the drawers and tool tray....I also have a lot of shop made jigs which I store on a wall and since the shop is in the basement and the ceiling is open to the floor joists, I also store and hang a lot of things there as well....the first two maple boards of the top extend out in front of the face of the drawer cabinet about 3 1/2" which allows for clamping all along the front and of course the dogs/holes as well which also clear the drawer cabinet below and there is additional clamping to the front by using the tool tray even though the bench sits against a wall....the drawers have never been an issue....they are recessed and out of the way as described above....I like the storage....as I'm getting more and more into hand tool work, you have to remember to take out tools that you will be using in advance if you are going to be clamping up some work that would block the drawers....but this is just a matter of having your head in the game....no problem so far....if you like to use bench hooks, a little planning around the Record vise would have yielded locations for holes (certainly the drawers limit this approach in their area)....as I try hand dovetails, I'm clamping the work to the bench using that 3 1/2" overhang....and the bench slave sitting behind the tail vise helps support the long stuff....the design will not work for everyone....but for case work, so far so good....I think I'll keep it.
roger lance
Pam....I've got Preview....but I'm a knuckle dragger :) so I'll have to explore this...thanks for that...it looks like a short session at Apple and maybe I'll be able to participate with photos....maybe even get into the 21st century.
Re: Lovely bench!
roger lance
David.... thanks for the compliment....I wanted to go old school on the tail vise and I find I really like it....it looks complicated and all wood except for the metal screw (see Jim's bench for use of wood screws) but it was not that difficult to make (there is a good description of how to make it in the Landis book)....it works very smoothly....no binding even with the seasonal changes....and it does not take much tightening to really hold the work firmly to the table.
Moses Yoder
Moses Yoder
If you can figure out how to resize your pictures so they are under 100 KB then it's easy to post them. You need a profile set up here, and your computer needs to be set to allow cookies. After a cookie is set, the screen that comes up to post messages has a place to upload pictures.
Although it really isn't much bother for me to post some pictures for you. I learned something today by doing it, actually.
If I had your bench I'd burn mine...
GolfSteve in Calgary
Nice bench, Roger. Are those fluted columns?
I love the look of the strong rectangular base with the drawers supporting the top. Much more attractive than the open base of the Klausz bench.
Someday I'll build drawers into my Klausz type bench.
Cheers,
Steven
Re: If I had your bench I'd burn mine...
roger lance
Steve....thanks....yes those are fluted columns....some of that embellishment that one has to try :D .
roger lance
Moses....I've not gotten down to the shop to take those nightstand photos as yet....after I do, I'll try Pam's suggestion....and if I muck it up (which is a real possibility), I'll e-mail you a shot or two (and that will be all a person could ask of another)....otherwise, I'll be on my own like a big boy....thanks again Moses!!....this has been fun!!
I'd prefer the housekeeper.......
Bill Tindall
Try as I might I can't get my housekeeper to keep my bench that neat and orderly.
Re: I'd prefer the housekeeper.......
TomD
I hear you. I threaten to fire the bench cat, but he doesn't seem to listen.
roger lance
Bill....remember when you were going to get your school pictures taken?....and you had to clean up a bit before hand.
If you ever do upgrade...
John in NM
I do recommend burning the old one :D
I built myself a bench when I first got out of college and could finally rent some shop space. Didn't know a whole lot, and it showed in the bench's construction.
When I later moved out of that space I gave the bench to a friend who rented in the same building, having figured out that the bench wasn't really very useful.
A decade later, that same $#*&! bench turned up in another friend's shop, who was appalled to learn that I had made it :D Someone I didn't know had been given this awful bench and was subletting a bit of space from my friend. I thought of offering $50 for it so I could burn it, but then I got curious to see where and when the stupid thing would turn back up in my life :D
Re: If you ever do upgrade...
roger lance
John....a bench has the potential to be like an ex-wife....might as well be a pretty one in case you have to meet up somewhere :) .
That begs the question...
John in NM
Why would you ever part with a pretty bench? :D
That one of mine turned up because it was so useless that no one would keep it long, and wasn't pretty to boot :D Simple probability dictates that I will likely see it again.
I should have tagged it with a GPS tracker the way a biologist might tag a squirrel... then I could follow it :D
