New WoodChat!
REAL MILK PAINT
Off Topic - spa thermostat
Our ancient spa, on which I've rebuilt the motor/pump twice, is having hot flashes. The rheostat-type temperature setting has become extremely sensitive and, after we've set it for a right temperature, in a day or two, it seems to trend upward. Tonight, it was so hot we thought we'd been turned into lobsters. I am assuming, given the age of the spa, that it's a bimetal sensor or some equivalent.
Do thermostats fail this way? Are we about to be shopping for a new spa? There's an unfixable slow leak in this one, so, if the thermostat's failing, it's probably not worth replacing it.
Re: Off Topic - spa thermostat
John Veerkamp
Yes , thermostats do fail over time. The bi-metal strips are laminated and sometimes the bonding fails leading to faulty operation.
Robin Corell in Atascadero CA
A couple years ago I had some problems with my spa and I found a lot of great info on spababes.com Her prices for parts are also the best I found.
