New WoodChat!
How do you all "soften" edges?
Bill Tindall
There are a lot of edges on 7 drawers and I like to soften them all. I don't like touching a sharp edge in furniture. I've tried block plane, spoke shave, sand paper. Yet another one of those things I have not settled and await sage advice.
Re: How do you all "soften" edges?
100 grit on a wood block....
roger lance
like you said a lot of edges....one of those unenjoyable time consuming tasks that make a world of difference.
Block plane
Usually - although it depends on my mood - a Stanley 60-1/2. While this is theoretically for end grain, for the tiny chamfer involved, it makes no real difference. The 60-1/2 fits nicely in the hand.
Ditto
Bruce, a MN Galoot
that was one of the first things I learned to do, many years ago. Call it intro to block planing, 101.
A worn piece of 220 folded into thirds
Re: A worn piece of 220 folded into thirds
Pam Niedermayer
That's pretty much my solution, too, but folded in two rather than thirds.
Pam
Re: Files
TomD
It depends on the edge one wants, I have used everything from a 1.5" radius roundover router bit, to 7" disc grinder. But most comonly I might shoot an edge with a block plane, then get in there with a file. I always liked the look of Krenov's edges, and I wondered what he used that would match up with the hand planes he states a repference for for the faces. Answer is files.
thanks
Bill Tindall
Don't know why that approach didn't cross my mind.
tried file, works great
Bill Tindall
Like all things hand tool, sharp is essential. A sharp file is a must or fuzzy edges will result with my usual collection of dull files.
Don't know how sage, but you might add a little at
Ron Bauman
When I worked as a machinist a thousand years ago there was always a little note on the blueprint "break all edges". I now do it with a chamfer plane. I use a Japanese plane I've had for 30 years. Its a look I like and it saves me and my customers paper cuts. It might be a bit severe for your purpose, but just a thought.
Re: tried file, works great
TomD
Glad you like it!
A more boutique thing that also keeps up with the polish off a plane is to use a burnisher. I use the one LV sell for scrapers, because it's there. This isn't going to work for everything, but it is very effective. It shines the wood up; it can do facets; it is very fast; not messy; and it will not tear out; though it can break over. Obviously not going to give you a massive chamfer. I use it for special situation, and small parts. I discovered this myself.
Charles
Fine cut file then a rub down with burlap. Unbeatable.
