New WoodChat!
On drilling holes for pulls in a bow front chest
Bill Tindall
If you have been following this adventure a previous installment involved wonderment as to how to drill the holes for the pulls on a curved surface. Anything but the correct hole orientation results in pulls that bind. This simple jig resulted in holes that were correctly spaced, parallel and most subtlety, perpendicular to the average tangent to the arc between the holes.
Two squares are used to locate the holes. (the clamp is just to hold the squares so I can take the picture) A prick with an awl marks the spot. After multiple checks to see the holes are indeed in the right place a shallow (1/4" deep about) pilot hole is drill at my best guess as to the correct angle.
Next the drilling jig is installed using two drills to align the jig with the shallow pilot holes previously drilled. The drilling jig is simply a "C" shaped piece of wood with two guide holes drilled perpendicular to the top surface and the correct distance apart.
After the holes are drilled the pulls are installed and they work as expected.
The location of the pulls was taken from a similar piece in the Connecticut Valley Furniture book (page 386)and the style was selected by my artist daughter. If it suits her it's fine by me!
Re: On drilling holes for pulls in a bow front chest
the end result looks great !
roger lance
Chuck Kettler
Grasshopper laments his exodus from ETN when it comes to missed opportunities to learn from the master.
how did you do the cock beading?
Ian (in Sydney, Australia)
very nice looking drawers there Bill
in another post did you cover how you attached the cock beading to the drawers?
if so can you point me there?
if not can you please elaborate?
cock beading a bow front-tedious
Bill Tindall
I may have posted this but i t may be easier to revisit. Normally I spend more time processing a picture for posting but there are a lot and I am short of time this AM. So, the pictures are more crude.
Step 1 is to temporarily nail an over sized piece of cockbead stock onto the rabbit in the top and bottom of the drawer front. Then plane the ends flush with the drawer.
Next, with a thickness gauge black mark how much the bead sticks out from the drawer.
Remove the bead stock, saw to near the guide lines and reinstall on the drawer. Next plane and spoke shave the bead to the guide line and flush with the inside of the drawer. I never got the guideline perfect so I in fact plane to near the guideline and then refine the amount that sticks out by eye.
Remove bead stock and scrap the bead profile.
mark where the miter ends in some previous step when the bead is temporarily mounted and using the jig illustrated cut the miter.
This picture may make more sense how it all goes together on the end. Note, the bead strip is upside down and reversed end for end as to how it is installed.
Last step is to install the ends. The rabbit for this piece is routed out.....being VERY careful to not chip out the veneer. I used a new bit and took first a light cut then then cut the remainder. The rabbit for the top and bottom piece is simply sawed off the drawer.
If ever there was a need for the "preview button" it is with this complicated post....
PS
Bill Tindall
maybe I told you how to build a watch and you asked the time......The bead is nailed and glued to the drawer and clamped while the glue dries.
Excellent tutorial, Bill, thanks
and nothing wrong with the photos, which show the steps clearly. This one may be a print-and-keep post.
Re: cock beading a bow front-tedious
Bruce, a MN Galoot
that might be enough to give me the courage to try those on my own, Bill. Thanks for the blow-by-blow.
Is your shop air-conditioned? There don't seem to be sweat stains on anything!
thanks very much Bill
Ian_N
