New WoodChat!
Dado depth question
Dado depth question
Dado depth question
wilbur
I'm planning an entertainment center, and I'm looking for a reality check. It's going to be a case about 60" wide, 24" high, divided into 6 compartments. I'm guessing the boards will be about 3/4" thick after being planed to final thickness.
As I tried to show in the picture, to hold the horizontal shelves, I'll need dados that are located opposite each other. The rule of thumb that I remember is that a single dado like this should be about 1/4" deep. At least, that's how deep I made the dados for the last project that required dados, but those dados were single dados, not back to back. This means that there will only be 1/4" between the dados in this entertainment center, which sounds like trouble waiting to happen.
How deep would you make dados for this task? And is the 1/4" rule of thumb that I'm remembering correct? Maybe I'm making dados that are too deep.
Re: Dado depth question
patrick gibbons
I always make my dados in wood that thick 3/8". I wonder if a half-lap joint might be better in this situation. Probably not.
patrick gibbons
Why not use 1" or thicker boards to support the dados better. The shelves could still be 3/4" and that would save some weight. Or you could attach ledges for the boards to sit in and not cut dados.
Warren in Lancaster, PA
Wilbur, I would be more concerned about the thin boards being flimsy than the dados. Unless you are after the old fashioned handyman look, 7/8 would be much better than 3/4. This is a big case. Even 13/16 would be a big improvement over 3/4. If you are preparing the material by hand, it is much easier to get 7/8 or so out of a 1" board.
As to the dados, 1/8 or 3/16 would be much better. Also you don't want to weaken your bottom too much with deep dados. You might also consider a full length shelf with verticals in shallow dados.
Moses Yoder
Moses Yoder
I would make the dados 3/16" deep. That is plenty of ledge to keep them from falling off, and leaves 3/8" in the center, which is plenty of strength. In period work I have seen these at 1/8" deep, and if everything is designed right works fine.
not an issue
Bill Tindall
The load will be vertical so it matters not how much wood is between the dados, except during assembly, where something too narrow will be frail and may be hard to handle. Once assembled this structure is well locked in in all directions and it will be as strong as the lumber. (when I make shelving with this much acreage, hardwood plywood becomes an attractive alternative)
You will no doubt used stopped dados which will help keep the double dadoed parts stiff until assembled, or do you intend to face this piece?
Adding a back will greatly stiffen and strengthen such a piece.
have you ruled out adjustable shelves ??
roger lance
wilbur
Going with thicker boards is certainly a good idea. I'll keep that in mind as I pick out the boards for this project.
I was leaning towards uninterrupted vertical pieces instead of a long horizontal middle shelf because my feeling is that it would be easier to deal with 5 boards 20-24" long instead of one long 60" board and four 12" long boards. But I'll revisit that idea, too.
Stephen Shepherd
Stephen Shepherd
Wilbur,
Are you wed to the idea of putting the center shelves all in one line? Consider making the center one higher by an inch or two, it will give a good look and solve your dado dilemma.
Stephen
