Hand tools, humidity, & the fight against....
roger lance
RUST. Well we are at the beginning of our annual heat wave in Michigan and the humidity is going up with the temperatures. So I thought this might be a good time to ask about opinions, strategies, products, and approaches to combating rust especially on hand tools. My shop is in the basement and I run a de-humidifer which definitely helps and I use Johnson's Paste Wax (silicone free) on the CI surfaces and this is generally effective. Also, I place one of those silica gel metal cased dehumidifiers from Lee Valley in each drawer that houses metal tools....these have the little window that shows a color change when it has absorbed its capacity of moisture and you then heat it in the oven to recycle it. I've also heard of a product called "Dry Right" which is suppose to be calcium chloride in bulk form....does anyone know about this, is it readily available, etc ?? Lie-Nielsen sells a couple of oils to wipe your tools...Camellia & Jojoba oils...except their shipping charges basically equal the cost of these products and I am not expecting a period of free shipping from them....again, does anyone have an opinion about these products or have other sources for them or other oils that they would recommend (or not) ?? Appreciate your insights....stay cool.
