New WoodChat!
REAL MILK PAINT
Well I'll ask woodworkers about Burnishers....
roger lance
What might your recommendation be of a burnisher for creating the burr on scrapers.....any preferences for the LV tri-burnisher or the LN carbide or will a Crown do the job just as well (and let you keep a few dollars for another day)....is there any real need for different shape burnishers or will a round burnisher suffice....this is the place where people have experienced these things and I'm looking forward to hearing your opinions. Thanks again.
Re: Well I'll ask woodworkers about Burnishers....
I use the shank of a large drill bit.
Phil Joines
You can put a handle on the spirley end if you want.
Even cheaper
Neal in San Jose
Do you happen to have a broken carbide router bit? That's what I used for a long time. I just epoxyed a broken quarter inch straight up cut carbide bit in a piece of dowell with enough sticking out to make a burnisher. Just make sure it's a carbide. The only reason I upgraded was because it was kinda ugly. If you do a better job than I did you may never have to upgrade.
Christopher Fitch Memphis
I like the tri-Burnisher...it works well for me.
Re: Another vote for LV
TomD
I like the tri burnisher, or maybe I have an earlier version when it was more oval. It is flat enough to leave a nice smooth edge, but not so flat it digs in. If you aren't getting scrapers to work, it isn't the lack of a 32 dollar burnisher, but it is extra nice to use. Of course mileage may vary depending on the English you put on it and the scrapers you use and edge you like.
Hi Roger
In a nutshell, what you need is a length of steel that is ..
1. smooth - free of any blemishes, since any nicks and scratches will transfer to the scraper steel.
2. harder than the steel of the scraper - you want to move steel on the scraper blade, not the burnisher
For this reason old screwdriver and chisel shafts are not recommended. They may work to create a burr, but the quality of this burr is unlikley to be the best. Indeed, the modern scraper blade may be harder than your vintage chisel back.
I use a shopmade burnisher - a length of thin carbide rod epoxied into a handle I turned. I like that it is thin. Not only does this make it lighter, which offers back more "feel", but it creater more pressure and I don't have to use great downforce (one must not anyway).
My burnisher and the larger Crown version ..
Assuming that you did not want to go to the trouble of making your own, I'd plump for the Veritas, which comes with a great reputation.
Hands down the very best.....
Bill Tindall
The other end of any 1/4" carbide bit. The bits used for edging Formica are a handy choice. Just drill and insert into some sort of handle or dowel. I buy the carbide bit blanks from the local saw shop. Many metal working suppliers also sell the carbide blanks. I think they are typically 3" by whatever diameter you want. I use 1/4".
nothing you will find is harder or slicker. I particularly like the "slicker" advantage.
