Re: building with green wood
TD
I spent about a K on my mill, new, and I had the same result, instant payback, assuming the wood gets used in the end. It sure is a cheap way to get wood to store.
There is a third option which can be the best, and that is turning. Turning has a lot of advantages over other things you can make with wood:
1) It is very fast, so you can actually get through the large amount of wood you will potentially receive.
2) speed and other factors mean the storage and drying, etc... options are pretty easy to deal with
3) You can use much smaller pieces of wood, and often get away with wood that is of a quality that you could never really use for much else. Though if you start with a perfect tree, you can often use the wood that gree woodworking would of the split and shave side would leave behind.
The biggest problem with wood is quality. Procuring your own wood will instantly give you a lot of respect for the trees that show up as perfect boards in your local supplier. Green woodworking sounds all funky, but it actually traditionally uses the very best wood there is. After that wood is gone people then figured out historically how to saw and produce wood products from the just that was lefte. And this is a process that is ongoing, and goes through multiple stages, right down to the point where they start making wood out of pop bottles.
Thinning out sounds as though you could be removing the bottom of the barrel, but so long as you are flexible about what you will make, you should be able to find some useable wood.
On option is a composite approach tool wise, where you use both modern and older techniques. I have spend a lot of labour getting a seemingly beautiful log out of the woods, down the beach, through the water, up the beach, sectioned, split, etc... only to find it really wasn't quite as nice as I had hoped, yet it would have been grade A if it was broken up on a bandsaw. The reality is that split wood construction requires wood that is above the grade required for aircraft and archery (arrrows), about the two highest grades I know of.
Also, consider that not all wood used in green construction is green. If you are using the method where dry and wet wood are brought together to shrink to a tight fit, your schedule will require that wood is available both wet, and dry.
