New WoodChat!
Chisel handle finish?
Paul Erickson
I am in the process of making a bunch of chisel handles, and would appreciate hearing people's thoughts on the best finish to use. My favourite finish it tung oil, but when I went to sharpen one of my early efforts on my water stones, that proved to be a mistake. I notice Derek uses BLO and wax. Would a final coat of wax be sufficient to stand up to the moisture issues posed by sharpening? Are some waxes better than others? What other options do people use?
Thanks in advance.
cheers, Paul
Re: Chisel handle finish?
Hi Paul
My recommendation is Shellawax. You can buff this while the handle in on the lathe, or you can do so with a mop on a drill press.
Shellawax creates a hard, clear finish that is waterproof, and very durable. Leave it slightly shiny, or rub with xxxx wool and wax for a natural look.
Paul Erickson
Thanks Derek,
Do you use the liquid, the cream, or the shine polish, or a combination?
cheers, Paul
David Weaver
A thin coat of shellac on the lathe followed by a 1:1 mixture of beeswax and light mineral oil applied with an abrasive pad and buffed.
I skip the shellac sometimes, I have a tub of beeswax with the mineral oil around all the time.
http://eddiecastelin.com/yahoo_site_admin/assets/docs/SandingWax.54184013.pdf
I saw this from a woodturner on youtube. It is so much nicer feeling to the hands than the petrol based waxes I've dealt with (minwax, johnsons, briwax), and you can refresh it very easily any time.
Only change I'd make is ordering the beeswax on ebay, where 100% pure non-pesticide beeswax can be had for around $5-6 a pound with no minimum. I'm not a wonk for the all-natural movement, but when it doesn't cost any extra to get it, it's an easy choice to get it.
Woodworking supply stores and michaels are out of their minds on what they want for beeswax. Way out there.
It cost me $15 to get two pounds of beeswax with shipping, and $2 a pint for the food grade mineral oil. That makes a quart of easy to apply (essentially edible and nontoxic) wax you can use on all of your stuff for $8.00 with shipping.
Second what Dave said.
Bob Hackett
Paul Erickson
Thanks Derek, will try it out.
cheers, Paul
Paul Erickson
Hi David,
Thanks for this. The idea of "rolling my own" appeals to me. I will probably try
both your suggestion and Derek's. So far the beeswax I have found is more expensive than the price you mention, but will keep looking.
One other thing. I don't understand the need for the two step mixing process. Why not mix the wax and oil all at once? I'm sure there is a reason, but it is obviously not clear to me.
cheers, Paul
David Weaver
Paul - I didn't follow the instructions exactly, either - I don't think it's critical to. I screwed up the first time around and ended up getting a hole in the ziploc bag and had a real party getting the oil and wax out of the pot I was using - it was all over the place in the pot mixed with the water and I ended up just dumping it out in the back yard.
I used a glass jar partially submersed on low heat the second time and that worked better (harder to screw up with the jar), but I ended up having not quite enough room for the oil to go 1:1 so my mix is a bit more solid and hard than a turner would use, but not as hard as plain beeswax. I kind of like it that way, it still buffs easy.
The seller I used on ebay was 35beeman
Don't know the guy, but I've ordered twice and received the stuff quickly. Cost $16 or something total last time, including shipping, for two pounds. Looks like the shipping is up a buck or two now from just the straight up flat envelope rate, but it's good stuff.
Moses Yoder
Moses Yoder
The best thing I have found is to use an oily wood like bocote or cocobolo for the handle then you don't need any finish on it. If you turn them round on the lathe they can be highly polished, but I like making octagon handles with some turning on the end so I don't polish them that much.
bees wax won't raise a blister
Robin Corell in Atascadero CA
I'm a big fan of straight bees wax on hadles but possibly for a different reason than the roll your own aspect. A thin coat of bees wax on unfinished wood provides a grippy surface vs a slippery smooth surface of a polished finish with a hard wax. in use the moisture from your hand will cause a smooth finished handle to raise a blister. A handle finished with bees wax is much less likely to raise a blister. Bees wax is also great on hammer and shovel handles.
Robin
David Barnett
Beeswax on chasing hammers? Absolute 'must have'.
David Barnett
Blisters?
Warren in Lancaster, PA
I am having trouble seeing how one gets blisters from a chisel. Lots of guys have chisels with smooth finish; I never heard of blisters from a chisel.
Ask Stephen
Dan Donaldson
He did a big carving job that got him some blisters etc.
