We value your privacy.
Following up on an earlier post of a new to me Yankee, does a North Brothers Yankee #35 screwdriver take the same blades as a #135 or similar? I am hoping they are universal. My Walters pocket guide and the Stanley parts web site does not have that information. Are any blades currently made or, is E-bay my best chance? I have a nice bigger flat blade but would like a few of the Phillips sizes. Thanks for the help as I try to mount a lot of hinges on some reproduction Chester County spice boxes.
This isn't much of an answer as Lee Valley shows three sizes but does not have the #35 listed,I have a hex adapter on one of mine which does help to use it with modern bits.I just check my shop and I have a 131 and a 130 which are different from each other but I do not have a 35/135 to compare with.
To answer your question right off: yes, the bits for the 135 driver (7/32" shank) will fit the 35 driver. There are multiple sources; I've linked Lee Valley's below. Their prices are good, although the notch in the shaft is not in quite the same location as and smaller than the notch in the original Yankee bits. In practice, this rarely makes a difference.
You've got an uncommon and way cool Yankee driver. I inherited one from my grandfather, through my father. Picture below, for those who've never seen one - similar to the 135 (at the bottom of the picture), but with a tee-tiny handle. For scale, the numbered stick in the middle is in inches.
They're intended for small work, obviously; they were delivered with bits for pretty small screws. I imagine they sold mainly to cabinet makers and furnituremakers, for installing hinges and cabinet hardware. Certainly, they'd be too small for daily production use for architectural hardware; the 135 is about the smallest I would think a carpenter would have had in the toolbox. Interestingly, though, the spiral shaft is only about 3/8" (guessed-at measurement) shorter than the shaft on the 135; and it's the same diameter, which is good, as any smaller and it would get fragile*.
I note that Lee Valley is now offering push drill bits to fit the 35/135 drivers. If you don't already own a push drill, you might consider buying one or two bits until you DO acquire one. While the spiral screwdriver isn't a great push drill (most Yankee push drills run backwards on the return stroke, clearing the swarf in the process), it's better than none; and push drills are way cool drills for small screw holes.
*Pronounced "Fraa-hee-lay." Technical word in Italian woodworking, similar in meaning to the English "fragile" ("fraa-jill") but with more style. Some automotive etymologists argue that it is the first word in the acronym "FIAT."
